350z tranny swap
Old Feb 11, 2011 | 09:42 PM
Z33FaNANtique's Avatar
Z33FaNANtique
Default 350z tranny swap
So I'm really thinking of doing this since I don't plan on selling the car. I have an auto 350z which is pretty sad i know. I miss driving my 6speed g35 but I had to sell it. Has anyone attempted an auto to manual tranny swap?
I know a shop who would do the swap which is paladin in las vegas.
Old Feb 11, 2011 | 09:53 PM
erichsherrill's Avatar
erichsherrill
You would need the following: Tranny, tranny mounts, shift linkages, shifter, console for inside the car to accept the shifter, ECU from a manual, COMPLETE engine/tranny wiring harness from the manual, clutch master cylinder, hydraulic lines, clutch pedal assembly, flywheel from the manual car, exhaust from the manual because the tranny is a little larger than the auto, and quite a bit of time.
prepare for flames from others tho
Old Feb 12, 2011 | 10:12 AM
ImWeeZzel's Avatar
ImWeeZzel
theres a couple of peeps that have done it
abushong is one of them
Sounds like an expensive idea, you might be better off getting an MT 350z instead
Old Feb 12, 2011 | 04:47 PM
cubs4worldseris's Avatar
cubs4worldseris
I would just trade in the auto and buy a 6mt Z.
Old Feb 12, 2011 | 11:42 PM
winchman's Avatar
winchman
Definitely not worth the effort, especially since the auto is better than the manual. What does it do/not do that makes you unhappy?
Old Feb 13, 2011 | 03:41 PM
doshoru's Avatar
doshoru
explain?
Old Feb 13, 2011 | 04:00 PM
erichsherrill
^ +1
Old Feb 13, 2011 | 04:37 PM
huyrua's Avatar
huyrua
Old Feb 14, 2011 | 02:12 AM
RAYZ33's Avatar
RAYZ33
Originally Posted by doshoru
explain?
gaytronic! durrrr....
Old Feb 14, 2011 | 04:24 AM
winchman's Avatar
winchman
It works really, really well. And it appears to keep working really well for a long time. Shifts are silky smooth in normal driving, crisp and solid in spirited driving, and it probably shifts faster than 95% or more of MT drivers can. Definitely the work of the A-team at Nissan.
The B-team gave you the breaking pivot bolts, hydraulic lines that get too hot, pedals that stick to the floor, the ill-conceived concentric slave cylinder, and hydraulic actuation systems that require superhuman skills and weird incantations to bleed.
Old Feb 14, 2011 | 09:05 AM
PeterSellers's Avatar
PeterSellers
...and a transmission that doesn't make the driver fall asleep at the wheel due to boredom.
Old Feb 14, 2011 | 09:43 AM
terrasmak's Avatar
Did you forget about the B team that gave you a trans cooling system that causes the trans to go into limp mode in just a few laps.?
Old Feb 14, 2011 | 10:23 AM
erichsherrill
yeah lets bring this debate back out so this thread can be closed
https://my350z.com/forum/2003-2009-n...l-is-cool.html
https://my350z.com/forum/2003-2009-n...is-better.html
https://my350z.com/forum/2003-2009-n...automatic.html
https://my350z.com/forum/new-owners/...al-tranny.html
https://my350z.com/forum/2003-2009-n...or-manual.html
https://my350z.com/forum/engine-and-...or-manual.html
https://my350z.com/forum/maintenance...automatic.html
Old Feb 14, 2011 | 10:24 AM
erichsherrill
i think u should trade in..
etkms
Jun 19, 2022 06:30 PM
SpartanZ32
Oct 22, 2015 09:36 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
Ace2347
Sep 22, 2015 03:12 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
