Motordyne gasket question
Old Mar 12, 2011 | 08:53 AM
rdrfronty's Avatar
rdrfronty
Default Motordyne gasket question
Quick question. I need to pull my lower plenum off my engine to do some lower intake work. Can I reuse the Motordyne lower thermal plenum gasket? It's the one that goes between the lower plenum and the lower intake. It's the thermal one that motordyne sale in a kit along with their 5/16" spacer set. And the built in spacer gasket, I assume that one is ok to reuse?
Anyway these have only been on for a month, and replacement Motordyne gaskets are pretty pricey if I don't need them.
So replace the lower gasket or reuse?
Old Mar 12, 2011 | 09:07 AM
daytonabluez05's Avatar
daytonabluez05
you should be able to i dont see why not, i would wipe the old coat of oil and put a new thin coat on it though to ensure a good seal.
Old Mar 12, 2011 | 11:51 AM
Mcutali's Avatar
Mcutali
Default re
coating the gasket with oil is this needed? the oem was dry as a bone. got new obx thermal just installed it never coated it
Old Mar 12, 2011 | 12:28 PM
rdrfronty's Avatar
rdrfronty
Motordyne says it needs a thin coat of oil. Strange, but the instructions say to do it. I assume it helps it swell to seal good.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
