Need help deciding on clutch/flywheel setup
I need to replace my OEM clutch very soon and was wondering if you guys could provide some input.
I am looking at two combo packages from TH Motorsports:
1. Exedy OEM clutch/ ACT Streetlite flywheel , $625
2. ACT clutch and Streetlite flywheel, $899
My car will never be boosted and it is a lightly modded 2005 DD (test pipes, exhaust, intake, coilovers). I am looking for universal basic setup for occasional track day, drift session or canyon run.
Do you think it is worth to spend extra $275 for option #2?
thanks,
thanks,
OP i personally have the JWT Clutch/Flywheel and i love it, but i have installed ~5 Z1 Motorsports clutch/flywheel combos and they feel nearly identical to my JWT, all the owners have been very pleased with them.
Thanks for input, I have preety much decided on the flywheel and Streetlite seems to be the best option there (limited chatter). The real question is if the ACT clutch is worth spending $275 over the Exedy OEM spec...
to say the ACT has no chatter is incorrect. I'm a HUGE ACT fan, have been using and offering their products for these cars since day 1, but every single lightweight flywheel for this car makes noise to one degree or another. Single piece units, like the ACT, do make a bit less than the multipiece units (like Fidanza/JWT) but they all will exhibit noise
It is a common issue in many vehicles, some heavy duty trucks come with dual mass flywheels that also come apart.
My car has only been TT for 6months, my OE flywheel came apart after 60k miles driven by an old man in bone stock form. I bought the car with a bad flywheel, installed the JWT Combo, went through all the NA boltons then Boost, so power wasn't the issue in the failing OE Flywheel.
