Anyone With Transmission Coolers?!
Old Jun 2, 2011 | 07:52 AM
exZilaration's Avatar
exZilaration
Question Anyone With Transmission Coolers?!
Hey guys I own an 05 35th Anniversary 5AT <-Yes I know flame on lol. And this is my 2nd tranny replaced by Nissan. I want to extend the longevity of my newer tranny so I dont have to go through this **** again . Apart from keeping up with the fluid i obviously want to add a tranny cooler. I've done some searching but i dont have any definite answers to my question.
Does my Z have a factory cooler?
What is a good cooler that some of you guys have used?
HOW DO I INSTALL IT?
Maybe some of you gurus can help. Thanks guys for any input.
Old Jun 2, 2011 | 09:41 AM
ImWeeZzel's Avatar
ImWeeZzel
By factory cooler you mean the AT radiator?
Install:
Options:
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
Sitting under my desk/waiting for install:
If you burn your transmission again then buy mine:
https://my350z.com/forum/drivetrain/...b-upgrade.html
^^^I'll even throw in a free trans cooler
Problem?
Old Jun 2, 2011 | 01:14 PM
terrasmak's Avatar
Are you boosted ? Do you track your car? The cooler is a simple/easy install, i do suggest getting a temp gauge and installing it at the same time, especially if you beat on your car.
Old Jun 2, 2011 | 02:39 PM
exZilaration
Thanks for the responses. So we dont have a factory A/T radiator?
And no im not boosted but I do track the car from time to time and I live in FL and its already up to 95ish degrees. I fear boilover when I track it
Old Jun 2, 2011 | 02:59 PM
terrasmak's Avatar
Yes your car has one but it does not cool enough for the roadcourse. It in plumbed into the bottem of the radiator. All you do is pick the cooler you want, mount it , unplug the one line into the radiator , run the line to the new cooler, then run the out on the new cooler back to the radiator. Simple and easy.
Old Jun 2, 2011 | 04:27 PM
exZilaration
Simple as that. Very nice thanks broskee I didnt know we had one from stock
Old Jun 3, 2011 | 07:48 AM
exZilaration
Do i just plug the holes in the radiator or would it be fine to leave it open?
Old Jun 3, 2011 | 08:04 AM
terrasmak's Avatar
No open holes, fluid will run from your trans to the radiator, radiator to the aftermarket cooler, then back to the trans.
Old Jun 3, 2011 | 11:12 AM
exZilaration
I get you know man so I'll still need the A/T radiator for the first initial phase. I was under the notion that we deleted it completely. Thanks terrasmak
Old Jun 3, 2011 | 11:22 AM
exZilaration
The pic Imweezzel posted didnt really show anyting but the cooler
Old Jun 3, 2011 | 11:40 AM
terrasmak's Avatar
YOu can install a MT radiator,( koyo, mishimoto, Mizu ) and just bypass the radiator all together. Thats what most of the FI and track guys do.
Old Jun 19, 2011 | 10:09 AM
exZilaration
I think ill make a DIY on how to do this
Old Jun 19, 2011 | 10:30 AM
lgear080's Avatar
lgear080
This is on my list too.
Old Jun 19, 2011 | 08:23 PM
exZilaration
i just got my cooler. Does anyone know which tranny line is the return from the radiator?
Old Jun 20, 2011 | 08:16 AM
DaveJackson's Avatar
DaveJackson
Master
Sounds crazy, but I think you just pull the line off while it's running to see which way it's flowing and quickly put it back on. (Wait for confirmation before trying this.)
Old Jun 20, 2011 | 08:26 AM
exZilaration
lol ive tried searching and i havent found anything. Im doing the DIY so i want it to be specific
Old Jun 20, 2011 | 08:50 AM
ImWeeZzel's Avatar
ImWeeZzel
The way mine is setup, if you look at the picture:
left hose is feed, right house is return. The reason I chose this method is because if the clock wise motion in the fluid.
I don't think it would matter, either way the cooler would cool down the fluid. If you criss cross your lines the cooler will still give you the same effect, but maybe the transmission will be affected?
Old Jun 20, 2011 | 03:00 PM
Resmarted's Avatar
Resmarted
Avatar is ****ing amazing.
Anyway, only the return and feed lines in and out of the tranny matter, a cooler should note if its flow specific
Old Jun 20, 2011 | 03:33 PM
ImWeeZzel's Avatar
ImWeeZzel
Exactly! The cooler should tell you if the flow of fluid is a specific direction, otherwise it shouldn't matter.
Her name is shay laren btw
Old Jun 20, 2011 | 03:40 PM
Resmarted's Avatar
Resmarted
tranny coolers, yeah...
shay laren, F*** YEAH.
I mean, im totally on topic here.
OP if you want ease of install, measure the ID (inner diameter) of the hose on the oem cooler and then find a cooler that uses that diameter fittings. Buy the same hose cut it to two hoses to be between 6-12 inches longer than oem ones (length will vary depending on where you want to mount the cooler). Then just swap the hoses, (ALL OF THIS ONLY AFTER DRAINING THE FLUID!) and have someone fab up some mounts and you are done. Hell if you are clever get some aluminum or sheet metal and ghetto fab your own mounts.
I'm to lazy to go look at what size the hose is, so you can do that yourself.
