CEL p1148
Old Jun 21, 2011 | 08:05 AM
OMG35S's Avatar
OMG35S
Question CEL p1148
Unfortunately, I am stuck with a Performance's Shop mistake.
Read More here : https://my350z.com/forum/north-east/...ml#post9214473
They replaced my Stock cats with aftermarket performance ones and managed to break what I believe is the Air fuel ratio sensor 1.
From the service manual:
P1148, P1168 CLOSED LOOP CONTROL
P1148
Trouble diagnosis name
Closed loop control function (bank 1)
DTC detecting condition
The closed loop control function for bank 1 does not operate even when vehicle is driving in the specified condition.
Possible cause
Harness or connectors (The A/F sensor 1 circuit is open or shorted.)
• A/F sensor 1
• A/F sensor 1 heater
Can someone chime in and tell me what this means? From the looks of it my Air fuel ratio sensor (bank 1) needs to replaced? Is this the Air fuel ratio sensor that is located on the passengers side header?
How easy is it to replace this sensor? Can I DIY?
Thanks
Old Jun 25, 2011 | 09:12 AM
doug_z's Avatar
doug_z
what year is your car check the fuse i shorted mine out and went crazy looking for the problem
Old Sep 24, 2011 | 11:51 PM
cocobrotha76's Avatar
cocobrotha76
i have the same code doug what fuse should we look for? code keeps popping up every few days.
Old Sep 25, 2011 | 07:13 PM
doug_z's Avatar
doug_z
there is one maybe two fuses in the fuse panel by they pedals one is labeled O2 this this only works for z that have wide-band style primary o2 sensors
let me know what you find
Bigsyke
Sep 11, 2015 06:19 PM
Darkspy
Sep 7, 2015 09:09 PM
guido51
Mar 31, 2005 06:26 PM
Dr Bonz
Sep 19, 2004 05:34 AM
