Cam install help
Old Jun 30, 2011 | 03:22 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default Cam install help
Does anyone know where there is a DIY for installing cams on a Revup, the one EM-EFER started never got finished.
I understand the whole front end needs to come apart (i'm replacing the radiator aswell anyway), but there is no detailed instructions on installing the cams and setting the timing right.
Anyone able to help out? Thanks.
Old Jun 30, 2011 | 05:51 AM
VQpwr03z's Avatar
VQpwr03z
i just installed my cams about a month ago i thought on doing it my self but huge mistake is a hell of job i would recommend you to get it done by a professional with the right space & tools.
Old Jun 30, 2011 | 06:38 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I'm not really scared of doing it, as i'm a marine engineer, and have done plenty of engine rebuilds. I just need a bit of help making sure i get it done in the right order.
Old Nov 25, 2011 | 10:31 PM
specialist's Avatar
specialist
Man i just put mine back together man i wish i had pics for you
Old Nov 25, 2011 | 10:39 PM
iheartmyz's Avatar
iheartmyz
I've got a couple pictures on my phone from when i did it, they'll probably give you a decent idea of what you're about to get into. pm your email address, hopefully it helps.
Old Nov 26, 2011 | 08:10 AM
binder's Avatar
binder
i have a DE manual in pdf form. You can find it online. If not email me and i'll send it to you.
It should be very similar to the HR even though it's not perfect. it will get you close enough that anyone with some mechanical skills should be able to get the rest of the way. The gears and chains all have markings on them to line up.
Old Jan 28, 2012 | 05:09 PM
rich2342's Avatar
rich2342
What are your mods? What type of cams?
