using a head gasket after installed but car not run?
Old Jul 26, 2011 | 03:16 PM
binder's Avatar
binder
Default using a head gasket after installed but car not run?
Ok, so i installed my heads with HR gaskets and 2 of my head studs pulled out. The most i got for torque was 80ftlbs on these heads when they needed to be to 95ft lbs.
My question is, since i never ran these heads would it be safe to reuse these gaskets or are they already wasted since they have had pressure on them? I've heard both sides of the fence.
I'm trying not to waste money because i'm already forking out **** for a new block but at the same time i don't want to run into issues by cutting corners.
Old Jul 26, 2011 | 04:11 PM
qqqqball's Avatar
qqqqball
are the heads o-ring'd? Rule of thumb is once compressed run or not do not reuse, I have seen people do it with mixed results
Old Jul 26, 2011 | 04:34 PM
2bad240's Avatar
2bad240
I reused a cometic 3 layer on my sr 5 times. And reused a set of cometics on my wrx engine twice.
But I don't know how the oem gasket compares. I would pull them out and look them over real good and make sure they are clean
Old Jul 26, 2011 | 08:38 PM
binder's Avatar
binder
they don't have any separate o-rings that go on the heads. They are a multilayer steel gasket so i'm not sure if there is a crush ring in there. I think the aftermarket companies use a crush ring.
Old Jul 26, 2011 | 08:42 PM
terrasmak's Avatar
They were never fully torqued , probably still good. Key word is probably
Old Jul 26, 2011 | 08:46 PM
binder's Avatar
binder
ya, that's what i'm worried about. since this new block doesn't have the cooling mod i probably should just go with some standard expensive aftermarket ones and take it up the *** like a blind consumer.
Old Jul 27, 2011 | 07:43 AM
Cass007's Avatar
Cass007
You're cracking me up Jeff. It reminds me of how I felt during rebuilds. After you do things right, then do them for the second or third time even the small expenses start to make you angry.
Old Jul 27, 2011 | 02:28 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I wouldnt reuse because even though they werent fully compressed they just about were there.
Chris350z03
Oct 8, 2023 07:19 PM
aarrgghh
May 1, 2022 11:04 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
smithmt3
Sep 11, 2015 08:25 PM
Inspatatrac
Sep 8, 2015 02:12 PM
