JWT Flywheel Install HELP!!!
Old Dec 11, 2003 | 06:16 PM
350Z_Redline's Avatar
350Z_Redline
Default JWT Flywheel Install HELP!!!
Does anyone know for certain if the diagram provided with the JWT Flywheel is showing the engine or clutch side? It looks like it's showing the engine side but I just want to be certain. I need to know where to put the alignment pin so that the timing will be correct but the diagram is rather ambiguous.
Old Dec 11, 2003 | 06:22 PM
FLY BY Z's Avatar
FLY BY Z
I don't know what the diagram looks like but the flywheel goes on first with the JWT logo facing to the rear of the car. Then the clutch plate goes on and you have to hold it in place while you put the clutch cover on over it. Maybe this will help you orient the diagram.
Old Dec 11, 2003 | 11:24 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
The surface area should face the clutch disk...
i will take a photo of the paperwork that comes with the JWT tommorow
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
