How do I install fuel pressure Sensor for gauge?
Old Aug 14, 2011 | 08:54 PM
brocw1093's Avatar
brocw1093
Default How do I install fuel pressure Sensor for gauge?
I have a fuel pressure gauge (glow shift) and can't figure out where to put the electronic Fuel Pressure Sensor with 1/8th NPT Male Threads it came with. How do I do this? Thanks
Old Aug 14, 2011 | 11:48 PM
winchman's Avatar
winchman
The service manual section EC has instructions for checking the fuel system pressure. You hook the gauge to a fitting near the front of the engine, probably on one of the fuel rails. That would be a good place to put the sensor.
Old Aug 15, 2011 | 12:29 AM
Sam Mcgoo's Avatar
Sam Mcgoo
The tidiest/safest way would be to use an adaptor on the end of the fuel rail. You fit one of the these between the fuel rail and damper then connect your gauge sensor in the supplied hole.
There are a few available at various prices.
http://www.dynotunenitrous.com/store...?idproduct=245
http://aamcompetition.com/i-4644835-...e-adapter.html
Old Aug 15, 2011 | 05:43 AM
brocw1093's Avatar
brocw1093
Would this work just aswell?http://www.z1motorsports.com/350_g35...c5e756ecce69cb
Old Aug 15, 2011 | 05:46 AM
brocw1093's Avatar
brocw1093
And thanks to both of you for the info
Old Aug 15, 2011 | 07:07 AM
str8dum1's Avatar
str8dum1
no, we dont use fuel lines like that.
you need the part listed in the links above
Originally Posted by brocw1093
