New G & Z Clutch Mod - Long Read
Old Sep 27, 2011 | 05:35 AM
ari_gold's Avatar
ari_gold
yea some visuals of what exactly your talking about would be nice.
Old Sep 27, 2011 | 05:41 AM
NorthernG's Avatar
NorthernG
Skip to the end.
Old Sep 27, 2011 | 09:40 AM
Italianjoe1's Avatar
Italianjoe1
So this will be applicable to an '07-08 car or no?
Old Sep 27, 2011 | 09:45 AM
bdavids1's Avatar
bdavids1
I'm also interested! Hate the Z clutch pedal...
Old Sep 27, 2011 | 10:39 AM
NorthernG's Avatar
NorthernG
Skip to the end.
Old Sep 27, 2011 | 01:07 PM
ZJoe's Avatar
ZJoe
I'm interested. I just got a much stronger clutch and flywheel and while the holding strength is more than double that of stock my clutch pedal is not as heavy as stock. YEAH! But, the window of engagement is small like you said. In for pics and put me on the list.
Old Sep 27, 2011 | 01:19 PM
Junkster's Avatar
Junkster
Interested in this product! How much are you planning on charging? 100 bucks?
Old Sep 27, 2011 | 03:37 PM
NorthernG's Avatar
NorthernG
Skip to the end.
Old Sep 27, 2011 | 03:42 PM
Italianjoe1
I'll see if I can get some pics of the bracket in my '08 in the next day or so.
Old Sep 27, 2011 | 03:50 PM
NorthernG's Avatar
NorthernG
Italianjoe1, That would be great! Look forward to seeing them when you get a chance.
Thanks
Ryan
Old Sep 27, 2011 | 03:52 PM
NorthernG's Avatar
NorthernG
Skip to the end.
Old Sep 28, 2011 | 05:25 PM
INTIMAZY's Avatar
INTIMAZY
Originally Posted by NorthernG
Here you go guys. I did up a little thing to explain what I mean about changing the fulcrum point. Cheers
A picture is worth 1,777 words (Yes, that's how many words your first post had.)
I'm interested.
My Tilton clutch is borderline nightmare to drive to and from the track
Old Sep 28, 2011 | 06:01 PM
NorthernG's Avatar
NorthernG
Thumbs up
Skip to the end.
Old Sep 29, 2011 | 05:40 AM
NorthernG's Avatar
NorthernG
Skip to the end.
Old Sep 29, 2011 | 06:33 AM
Junkster's Avatar
Junkster
I am interested but i am curious to read up on a install how to before im 100%
Im still kinda meh about the install lol
Old Sep 29, 2011 | 03:03 PM
ZRC's Avatar
ZRC
NortherenG,
Hope its not to late to throw my name into the mix here to test that mod out.
I am currently having to swap motors on my 04 Z and since its coming out I am doing a lot of upgrade and would love to add your mod to the list.
Thanks in advance
-Zac
Old Sep 29, 2011 | 05:45 PM
INTIMAZY's Avatar
INTIMAZY
Just wondering if you plan to include alternate holes for mounting the pedal pivot point. I'm asking because my clutch requires me to run a clutch pedal stop so my actual clutch travel is very short already (just a plate and bolt mounted to the firewall the keeps the pedal from being overstroked). I was hoping to possibly "move" my clutch pedal travel closer to the firewall along with the benefits you described with extending the actual "slip" zone.
Old Sep 29, 2011 | 06:40 PM
  #38
NorthernG's Avatar
NorthernG
.Skip to the end.
Old Sep 29, 2011 | 08:35 PM
  #39
derektm's Avatar
derektm
INTIMAZY, The pivot point of the pedal will remain fixed in the new brackets just as it is with the factory one. What I’m including though is a new clevis for the clutch rod and 3 swappable adapter blocks that go between the pedal arm and the new clevis to modify the location of the fulcrum relative to the fixed pivot point.
To re-align the pedal to the master cylinder as the fulcrum point is raised the entire clutch bracket is lowered (in stages) by the same amount the fulcrum is raised. By doing this the geometry between the pedal, clevis and clutch rod remains unchanged. Otherwise as you raise the fulcrum from the stock position the clutch rod would be pushing on the master cylinder at an angle instead of straight in and out which is very bad for it.
Now to answer your real question the new pedal bracket has built in fully adjustable pedal stops to accomplish the same as your bolted plate.
However since the master cylinder isn't being pushed as far for the same given pedal stroke as before you gain back the use of your pedal range, widening the friction zone, yet still not over traveling your clutch throw out.
Hopefully that answers your question.
The higher the stage selected, the less your master cylinder actually moves for any given pedal travel.
For arguments sake say the stock setup pushed the master cylinder 1" in with a full 5" of pedal travel.
Now put in the stage 3 components and the master cylinder now only moves 0.5" for that same 5" of pedal travel.
In theory you've done half as much "work" over the same pedal distance traveled making the pedal much easier to push and giving finer control of its movement.
Now don't worry about the pedal softening as I still can't lift my foot faster then the clutch can spring back on its own barking the tires into second and third on command.
Count me in. I'm curious to try out what you've come up with and see how well it works.
Old Sep 29, 2011 | 09:40 PM
  #40
TurboTom's Avatar
TurboTom
subscribed, If this mod works for the 07-08 350z then count me in.
If it doesn't and your product for the 03-06 is a sucess would you make another product for us 07-08 350z guys?
