Looking for Mount kit for RB26DETT--->my 350z???!!
Old Sep 25, 2011 | 10:16 PM
z33.nosh1t's Avatar
z33.nosh1t
Default Looking for Mount kit for RB26DETT--->my 350z???!!
After doing little research, I have only come across few, small privately owned shops that are fabbing up motor/tranny mounts for a RB26 swap into a 350z chassis. Lots of threads only talk about ballpark pricing for this swap and I would like to talk to anyone who can give me any solid information.
So that being said, does anyone know about a company making good quality, machined motor and tranny mounts with polyurethane bushings? Custom driveshafts?
Old Sep 26, 2011 | 01:19 AM
midz350's Avatar
midz350
http://cmsperformanceonline.com/inde...tegory&path=44
Old Sep 26, 2011 | 01:51 AM
Spork's Avatar
Spork
Oh god... and I can source an RB26 for $1-2k. Looks like an 03 Z might be my cheap project when I get back to the states.
Old Sep 26, 2011 | 11:42 AM
z33.nosh1t's Avatar
z33.nosh1t
Ive looked at CMS performance's website, and it seems out of date. There are no customer reviews and after doing little research on the company I found out that their shop was burned down for some odd reason...Not a very reputable source imo
Old Oct 5, 2011 | 08:08 AM
ZGdude's Avatar
ZGdude
Cms performance is open and running????
there website looks ok not outdated??
just call them and talk to them find out for yourselfs....i mean the phone # is right on the home page it must work.
Old Oct 5, 2011 | 09:42 AM
ZGdude's Avatar
ZGdude
here is there facebook looks active to me
http://www.facebook.com/cmsperformance
Old Oct 5, 2011 | 11:35 AM
nismo69's Avatar
nismo69
I talked to them today. Very nice to talk to you and will tell you everything about the swap. I keep going back and forth from this to a ls motor. Since I already have the ls motor I will most likely stick with it. Leo said they were in the middle of doing another car right now.
Old Oct 5, 2011 | 01:32 PM
bigcloud's Avatar
bigcloud
Here you go. JE Import Performance does the RB swap as well as the LS swap. Check them out.
http://www.jeimportperformance.com/e...g35_350z_swaps
Old Oct 13, 2011 | 10:39 PM
z33.nosh1t's Avatar
z33.nosh1t
So after doing some hunting, I have found that JE imports does make the kit on order. Also, Mkinney is in the production stages of this mount kit and they are looking to have it available for Feb. 2012. Thanks for all the help guys
Old Oct 14, 2011 | 04:20 AM
Cass007's Avatar
Cass007
Good luck with the swap OP. JE is solid and works with SIKKY (the LS swap guys) to help make parts.
I would love to see the end result and cost analysis of this build.
Old Oct 17, 2011 | 11:45 PM
z33.nosh1t's Avatar
z33.nosh1t
Oh, well thats good to know!
I will most definately keep you posted
Parts list so far:
350z shell
RB26 n1 Motorset
HKS full t04z kit
HKS FMIC/BOV
Sard 1000cc injectors/fuel rail/ FPR
Tomei cams/ cam gears
Koyo rad
Project Mu BBK
more stuff..... ill start a build thread once i get the mount kit
some things to keep in mind when doing this swap are intake manifold fitment(some say space is an issue, I have seen both stock and aftermarket setups being run though), oil pan machine work to delete AWD/ and fitment of subframe, all custom piping for intercooler/ exhaust, shifter fitment in comparison to VQ tranny, mount kit of course including new front crossmember/mounts/tranny mount/driveshaft
wiring of course is a ***** best bet is to go painless.
There is no return line on the 350z fuel tank so changes have to be made in order to make the fuel system work with the rb26 setup
so far I figure these are most of the major steps needed to be taken care of to make it happen
Old Oct 18, 2011 | 06:48 AM
bbs350z's Avatar
bbs350z
^go fuel cell or add a return fitting to your stock pump basket.
also i got a guy that will do your wiring. hes doing mine ad vas33's ls retrofit harness and theyre fully tucked (he had an rb25 in his 240, now vq35 so hes very familiar with the rb family)
Old Oct 19, 2011 | 01:21 PM
z33.nosh1t's Avatar
z33.nosh1t
does the rb26 need to have a return in the fuel line? the sard fuel rail i aquired has a plug fitting that it came with, and the fuel rail is vehicle specific, so it kind of makes me wonder.. I think i would rather just put a return fitting in the basket like bbs350z says.
Im located in Canada and i have a friend that does wiring, i think im going with the full painless kit
Old Nov 19, 2011 | 06:23 AM
jdepe's Avatar
jdepe
Would you still be able to pass an obd2 emissions test. Here in TN. They just hook your car up to an obd2 scanner and as long it you don't throw any codes, you pass
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
