350EVO.....Fluidyne street version radiator
Old Dec 16, 2003 | 12:20 PM
dwnshift's Avatar
dwnshift
Default 350EVO.....Fluidyne street version radiator
Ta Daaaaaa
This is it prcing and availabilty info soon.
We use the race version on our Grand Am Cup car which can handle up to 1000 HP.
Cheers
BJ@350EVo.com
Attached Thumbnails 350EVO.....Fluidyne street version radiator-radiator-002.jpg
Old Dec 16, 2003 | 12:23 PM
John's Avatar
John
That's one friggin' huge radiator! Thickness?
And your racecar can handle up to 1000hp?
azrael's Avatar
azrael
very cool.
what power level can the "street" version handle?
I'm a big fan of the aluminum endtanks. I'll never understand why they use plastic endtanks on street cars. I can't count the number I've seen that leak.
Old Dec 16, 2003 | 12:52 PM
dwnshift's Avatar
dwnshift
I wish the racecar was 1000 HP!
The only differnce that I know of is that this one has all the proper mounting tabs for the A/C condensor.
Should be able to handle up to 1000 HP also.
Old Dec 16, 2003 | 01:03 PM
VandyZ's Avatar
VandyZ
Fluidyne's are awesome!
Old Dec 17, 2003 | 07:32 AM
dwnshift's Avatar
dwnshift
Just got word.this is the new prototype for fitment. Its going in my Z tomorrow for final checking.
Looks like Spring time 2004 for availability.
Old Dec 17, 2003 | 07:43 AM
350zSpeedRacer's Avatar
350zSpeedRacer
BJ, you've GOT to quit putting things out there for me to spend my money on.
Old Dec 17, 2003 | 01:51 PM
MY350Z.COM's Avatar
nice alternative to the 1K ARC radiator.
Old Dec 17, 2003 | 02:03 PM
dwnshift's Avatar
dwnshift
Fluidyne is top notch when it comes to performance and quallity. I believe the final production unit will be around $600 and will be available at 350EVO.com.
I am doing the fitment on this unti tomorrow.
Old Dec 17, 2003 | 05:31 PM
little_rod's Avatar
little_rod
Man, you guys put out top notch stuff. Now if we on my350.com could get a top notch discount....
Old Dec 18, 2003 | 06:04 AM
dwnshift's Avatar
dwnshift
Workin on it!
BJ
Old Dec 18, 2003 | 04:00 PM
little_rod's Avatar
little_rod
Well, I for one, love you guys stuff. Bit rich for my tastes, but great stuff. A break on the pricing might sway (pun intended) me to buying from you guys.
Old Dec 18, 2003 | 04:28 PM
dwnshift's Avatar
dwnshift
Quallity!
Old Dec 18, 2003 | 04:58 PM
little_rod's Avatar
little_rod
High quality stuff can still cost too dang much, lol.
Old Dec 28, 2003 | 09:06 AM
abogada001's Avatar
abogada001
Will this fit a G35?
Thanks
Robin
Old Dec 28, 2003 | 11:41 AM
dwnshift's Avatar
dwnshift
If the front plastic clip and fan shroud is the same then yes.
Old Dec 28, 2003 | 11:48 AM
MY350Z.COM's Avatar
I think the G35 uses a belt operated fan.
Someone correct me if I'm wrong.
Old Dec 28, 2003 | 03:24 PM
gould2000's Avatar
gould2000
Certain G35 use a belt driven fan. The A/T sedan version does. While the M/T version of the Sedan uses the electrical version.
If it does fit, there may be some minor hose and line modifications needed due to the location of said hoses and lines in the g35 vs the Z. Found this out while trying to find the best way to have an inlet filter on an ATI equipped g35. Some radiator housing related stuff was different between the G35 and the Z, if I remember correctly.
Old Dec 28, 2003 | 03:27 PM
dwnshift's Avatar
dwnshift
thanks for the info....I will pass it along.
Old Dec 28, 2003 | 03:34 PM
abogada001's Avatar
abogada001
Mine is a 6MT with electric fans, btw did you ever mount a filter on the procharger unit itself?
Robin
