Engine build need help
Old Oct 13, 2011 | 07:19 AM
wbama387's Avatar
wbama387
Default Engine build need help
So i hang out on driver and have a question. I am in the process of a stroker build 97mm bore with arias pistons. I called arias and they recommended .026" ring end gap on the top ring and .021" on the middle. From my understanding you want the second ring the same or larger because other wise it can cause flutter. What are yalls opinions.
Old Oct 13, 2011 | 08:02 PM
Eno's Avatar
Eno
Eh Bama... see you around in driver- your build thread over there is epic.
The guys over on the FI side would probably eat this up and probably bring you the information you're looking for... This area isn't as busy.
Maybe a mod could move it over there for you because it's DEFINITELY related to FI.
Hope someone can help!
Old Oct 14, 2011 | 07:15 AM
wbama387's Avatar
wbama387
i was wondering why i hadnt gotten a response because i heard there were a lot of people over here that should know this technical stuff.
if it doesnt get moved i will just restart it in the forced induction section. thanks.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
