Ok So How Much Power Can I Get For 10K In A 08 MT?
Old Oct 22, 2011 | 09:21 AM
juniboy51's Avatar
juniboy51
Default Ok So How Much Power Can I Get For 10K In A 08 MT?
Ok So Here's The Deal.. I Have A 2008 350z Grand Touring 6MT With 32,4XX Miles And And I Got About 10k That I Would Love To Invest In My Car.. It's My Daily Driver How Much Power Can I Get Keeping In Mind I Want Reliablilty... Anything But Supercharger! Tell Me What Setup Can I Get With 10K That Would Be Reliable And How Much Power Will It Make...( I Would Love A Turbo But Do I Have Enough $) Also I Got A 540Whp IS300 I Bought It Build So I Love The Turbo!
Old Oct 22, 2011 | 09:23 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Look at the vendor section...plenty of shops offering turn key packages for under 10k.
Undo your caps lock too!
Old Oct 22, 2011 | 09:27 AM
hugo350z's Avatar
hugo350z
Why not keep the 10k, use the Is300 as a toy, and the Z as a daily?
Old Oct 22, 2011 | 09:31 AM
s5pitfire's Avatar
s5pitfire
put your flame suit on, this has been asked a few thousand times. Anytime you go forced induction you lower the reliability of the motor, and even if it is built up, you have more moving parts and potential exhaust leaks, etc.
https://my350z.com/forum/engine-and-drivetrain-50/
If I had $10k and wanted truly reliable DD, i'd do boltons such as intake, headers, test pipe (or high flow cat), cat-back exhaust, motordyne 5/16th" plenum spacer, popcharger intake, coilovers, nice staggered 18" wheels. And tune. Should be good for ~30whp
You'd still have a few thousand left, going deeper would be cams
Old Oct 22, 2011 | 09:35 AM
Frosty87's Avatar
Frosty87
buy a greddy 20g kit turn it up to 20 psi you'll make about 700whp on pump it will be awesome..
Old Oct 22, 2011 | 10:25 AM
JCITY's Avatar
JCITY
Cool
You can get a single turbo..Momentum is a good one,for that price.
Old Oct 22, 2011 | 10:27 AM
AngelsVQ's Avatar
AngelsVQ
232.3 hp gain with 10k$
But seriously. Check out momentum performance. They have a sick single turbo kit that willdo fine on stock internals and conservative tune. Should keep you In budget
Old Oct 22, 2011 | 10:41 AM
ronn1's Avatar
ronn1
If he has $10K set aside I would go for it. I would be conservative with FI and get the supercharger kit 8lbs boost max. GTM (see Thread here) has a very nice set up. You'll get a LOT more performance for the $$ than bolt ons.
Old Oct 22, 2011 | 10:47 AM
faiz23's Avatar
faiz23
FEZZZZZZ
Momentum Performance Turbo Kit: GT35R TurbO
FIC 775cc Injectors
New Aeromotive 340 HP Fuel Pump
Custom UpRev Tune w/ License
PS Turbine Blanket - To reduce temps
Installation
Configuration
$8,649 Installed
$7,995 Installed! > FOR A VERY VERY VERY LIMITED TIME!
http://g35driver.com/forums/florida-...turbo-kit.html
Edit: As pointed out this kit only works on G35/350z. OP you would need to look at Greddy kit or GTM and both will run you over 10k installed and then set aside money for a rebuild once it goes POP!!!
Old Oct 22, 2011 | 11:03 AM
Frosty87's Avatar
Frosty87
Wow sweet you posted a turbo kit for the vq35de .. while he has the vq35hr ...do you guys have this installed or your hr z or have a fi z in general.
Old Oct 22, 2011 | 11:12 AM
abarclay's Avatar
abarclay
Don't forget gauges, clutch, exhaust, etc. if you're thinking of going FI. Not to mention some extra bones for when an OEM part fails. 10k can disappear faster than you think.
I'd stay NA, do the normal bolt-ons, coilovers, and wheels. $0.02
Old Oct 22, 2011 | 11:22 AM
silvertouringz's Avatar
silvertouringz
stay N/A..full bolt on+cams
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
LOL @ the guys recommending a VQ35DE turbo kit to the OP who clearly stated that he has an '08 Z.
Old Oct 22, 2011 | 01:33 PM
AngelsVQ's Avatar
AngelsVQ
I looked over the 08 part!
I'm curious. Why do you not want a supercharger?
Old Oct 22, 2011 | 02:19 PM
Bmurray350z's Avatar
Bmurray350z
this
Old Oct 22, 2011 | 02:26 PM
str8dum1's Avatar
str8dum1
you dont have many options. Greddy or GTM is it for turbo kits. Both are gonna run ya pretty close to 10k installed and tuned with only the bare minimums for safety.
Old Oct 22, 2011 | 02:45 PM
Frosty87's Avatar
Frosty87
I think he's yelling but only at the beginning of the words
Old Oct 22, 2011 | 04:12 PM
anyjuan's Avatar
anyjuan
LS1/LS2 swap if you dont want to go FI. HR Twin turbos will cost about 11k+(installed), Supercharger maybe $7k+(instaled). The HR will hardly get 30whp with bolt ons. Maybe just go all out on wheels, exhaust, suspension and brakes. Then whatever you have extra keep as track day money.
Old Oct 22, 2011 | 09:12 PM
With a little work I think we can make it fit.
