Help me decide on an engine
Old Oct 23, 2011 | 02:29 PM
Fluid1's Avatar
Fluid1
Default Help me decide on an engine
It's going to be some sort of LS. Goals are 500-550rwhp n/a, setup for a 150-200 shot on top of that.
LS9 not an option. I'd like to do it as cheaply as possible obviously, and would prefer to not just buy a crate engine.
Old Oct 23, 2011 | 03:36 PM
Cass007's Avatar
Cass007
Passing on advice Vas gave me. Find an LS2/T56 dropout from a 05-06 GTO and your off to a solid start. If you are going to do a full build, an LS1 or even the iron truck block (I forget the designation) will save money and then just punch it out to a 383 or 402.
The GTO dropout will run you ~$6500 shipped from someone like LKQ. I found mine on Ebay, but the ls1tech forum is a great resource as well as you know.
Welcome to the darker dark side
Old Oct 23, 2011 | 04:43 PM
Fluid1's Avatar
Fluid1
What would it take on a 05-06 GTO LS2 to get it to 500rwhp prior to n2o? Plus, shooting 150 on top of that, I'd have to build pretty much anything right?
Old Oct 23, 2011 | 04:58 PM
Quamen's Avatar
Quamen
You will definitely need a cam and intake manifold to hit your goals. The cam will need to be quite aggressive so you will need push rods and springs. Rod bolts will be a minimum for spray but honestly 500whp and a 150 shot will require a built bottom end if you plan on beating on it more than a couple times.
My opinion is go with an LS1/LS6 so you save enough money to buy forged internals. You can still make high 400's NA and have a near bullet proof motor.
Old Oct 23, 2011 | 05:17 PM
Fluid1's Avatar
Fluid1
Originally Posted by Cass007
Find an LS2/T56 dropout from a 05-06 GTO and your off to a solid start. :
4 posts so far, and two quite different options. I'm glad I started this thread! Compare and contrast the two... what are the benefits/negatives of each? Keeping my goals in mind, of course. I suppose I would be cool with 450 rwhp and a 200 shot
Old Oct 23, 2011 | 06:08 PM
WTFMike's Avatar
WTFMike
Well, if you want an LS motor....buy a B18b, found in the mid 90's LS integras.
J/K
Old Oct 23, 2011 | 07:04 PM
Rambo's Avatar
Rambo
I am building an LS6 and I am building the enitire motor myself. I do not know why you need 550hp with nos. What is the goal? Dyno queen or strip car. If this is a driver or autocross car 450 NA is plenty. Have you ever driven a vette? An ls motor is nothing like our cars...it has real power.
Old Oct 23, 2011 | 07:32 PM
Quamen's Avatar
Quamen
Fluid1,
As you may or may not know I have had an LS in my Z for over a year now. Last year it was just a bone stock LS1 with a TH400 three speed that put down 322whp. What I can say is that in that trim the car was still extremely fast. Now my car is stroked, high compression and on a massive diet... the car is simply a beast.
The reason that I recommended what I did is because based on what you are looking for it sounds like you will need quite a robust motor. A stock LS2 is not going to handle 500whp plus a 150shot of nitrous very long. The end result will still be a built motor. Now if you have the money to swing buying an LS2 and building it go right ahead. If not, save the money and buy the .3L smaller LS1 and build the bottom end to handle as much nitrous as you want at it.
I don't want to offend you because I don't know the cars you have had, but a 450whp LS is far from settling. It is nothing like a 450whp VQ. Remember, this is coming from someone using a three speed with a first gear that goes to 54mph and second gear that goes to 91 mph on my street tires with a stock 6,000rpm redline. 58mph and 98mph respectively on my race tires. I highly doubt that a 450whp VQ would seem especially fast with my setup, but the LS is simply amazing in my car. Now put a six speed in there with significantly more mechanical advantage and less parasitic loss than my TH400 and I would find it even harder to believe that 450whp can't meet your needs on the street. Beyond that the nitrous will take car of the rest at the track.
Old Oct 24, 2011 | 05:07 AM
Fluid1's Avatar
Fluid1
I have heard this more and more as I go. I don't have any specific goals, won't be racing the car and maybe take it to the strip once in a while. Just a car I'll drive about 3 times a week. I'll give a little history I guess.
I've had 18 vehicles. Only one was a truck, two crotch rockets, and I'd say 10 were heavily modded. The 350Z I just had pop was my 3rd Z. It was the second one with turbo, and I had it at various stages. Most recent was over 600rwhp. I've raced road courses, been very very fast, and am looking to make a street car that will be faster than nearly anything on the road, bikes, turbo lambos, etc.
My goal was 700 wheel. I know that's an insane amount of power. I figured 550 n/a and then a 150 shot on top of that. Everyone and their brother are telling me I'm nuts though.
Quamen, what was the reason behind your particular tranny setup? Wasn't it much harder to customize than the T56/Sikky? I mean I know the drawbacks of the T56....
Old Oct 24, 2011 | 05:32 AM
Quamen's Avatar
Quamen
Well it sounds like a high powered vehicle will be no problem then. Good tires will be absolutely essential to make this happen with a 500whp+ LS in the Z, especially with a six speed.
You should talk to SnyperZ about this and how his car was on the street. While I won't say the Z would be unmanageable at the track with that power, the street will be a different story. From a roll you should be able to manage that with good tires but the lower gears will still be useless.
I personally think the TH400 was easy to install in my car. Had I used a Sikky mounting kit it would have been even easier since the motor would have been further forward. Since I made my own kit my motor sits about a 1/2" from the firewall and I had to tap some clearance into the tunnel near the bell housing. The rest of the transmission has tons of clearance other than right near the block. My primary reason for choosing the Th400 was my car is a drag car and the automatic is faster than the T56. However, I must say the automatic makes the car much more manageable on the street and I feel I have have more traction due to the taller gears. Being able to accelerate in 1st gear is nice for a change.
Old Oct 24, 2011 | 06:52 AM
TehkMob's Avatar
TehkMob
Turbo Lambo? Aiming high with a low hp car no? Maybe it's just Texas, but turbo lambo's here run 1300-2000 whp... tx2k11. You tube the **** people have down here... If you don't have 900+hp Midas well watch and save your gas. Def build a LS1/6 lots of guys are building the ls1/6 for pro chargers and getting amazing results. I doubt your going to be running a 200 shot very long, especially without building the bottom end. Your better doing a fullon bottle fed build, or full on na build...
To run shots that's size your motor has to be built for it to last. At that level it's just like going fi. It all comes down to timing, tuning and legit parts.
Far as options.
LS3 from a truck, (cast iron block)
LS1 (5.3 also from a truck)
Both are pretty cheap and easy to source.
Or if you want I have a already built by lingenfelter ls1/6 good for 430hp and thats on a ls1 intake.. Swap to the ls6 unit for another 15-30hp and you have your engine.. Pm me in your curious..
Old Oct 24, 2011 | 07:29 AM
Quamen's Avatar
Quamen
Originally Posted by TehkMob
Def build a LS1/6 lots of guys are building the ls1/6 for pro chargers and getting amazing results. I doubt your going to be running a 200 shot very long, especially without building the bottom end. Your better doing a fullon bottle fed build, or full on na build... To run shots that's size your motor has to be built for it to last. At that level it's just like going fi. It all comes down to timing, tuning and legit parts.
That is exactly why I built my motor with Callies and Diamond components directed specifically at nitrous. Without good components and rings/pistons specifically speced for nitrous the motor won't last very long.
Old Oct 24, 2011 | 08:14 AM
Fluid1's Avatar
Fluid1
Far as options.
I am 100% curious. Please let me know what you're thinking!
Old Oct 24, 2011 | 08:16 AM
Fluid1's Avatar
Fluid1
Underground Racing is here in Charlotte. Youtube them too
I know what I'm getting into and I'm serious.
I'm ready to do a full on bottle build. LS1 or LS2. That is the question. lol
Old Oct 24, 2011 | 08:17 AM
Fluid1's Avatar
Fluid1
Well, it sounds more and more that you have what I want.
A beefy n2o setup.
Old Oct 24, 2011 | 11:05 AM
Fluid1's Avatar
Fluid1
Sounds to me like the option I'm headed towards is the LS3 (iron version of LS1) built up to handle boost, run a rear mount, shoot for a lil more than 600rwhp and call it a day.
Now. Who's got one for sale? lol
Old Oct 24, 2011 | 11:31 AM
Quamen's Avatar
Quamen
Why the iron block for only 600whp?
Old Oct 24, 2011 | 11:49 AM
TehkMob's Avatar
TehkMob
I think he wants that to start and add more power later. 600 on a ls3 will be easy on boost.
Old Oct 24, 2011 | 12:57 PM
scardeal's Avatar
scardeal
I hear the 4.8s can take LOTS of boost... I'd say a 4.8 turbo setup.
Just trying to think outside the box here.
Old Oct 24, 2011 | 01:04 PM
jerryd87's Avatar
jerryd87
please dont buy a ls3 thinking your gona get a iron block ls1 you will be very sad when you get it lol. all the ls# rpo codes are aluminum block, ls1 is the 5.7L aluminum block, ls2 is the 6.0L aluminum block, ls3 is the 6.2L aluminum block with variable valve timing. theres also the ls4 which is a 5.3L aluminum but stay away as its for fwd vehicles like the grand prix gxp.
For iron blocks you want the lq4 or lq9 for the 6.0L, the other options are the 4.8L which i dont know the rpo code for and then also the 5.3L which is the LY5 or the or LMG there is no 5.7L iron block.
What you can do for 5.7L iron block is get a 5.3 and bore it out, there is actually so much meat in the walls that it can be done and still have the same wall thickness as a small block 350 with a .030 overbore. personally i would keep it as a 5.3L though with the extra thickness and never have to worry about the block itself.
There are also several other people who have done the 5.3 swap into things or boosted the power significantly. one magazine ran new heads intake and extreme cam in it making 600 at the engine at 8k rpms, another dude swapped one into his ford falcon with heads and cams and was making 800 hp to the wheels on a stock bottom end through a procharger, had about 8k miles on it when the article had been done. One of the magazines in july when i was on r&r i saw was trying to blow up a 5.3, has it up to 1200 hp at the crank and it was still holding.
There is one other engine the only aluminum block to be put into a truck to my knowledge is the l99 its a 6.2L with variable valve timing as well.
outside of the ls4 all of them share motor mount points and bolts patterns for the bellhousings. i could be wrong on the no 5.7L iron block as well as its been several years since i worked at the dealerships but im 98% sure on it.
