2004 350Z clutch question
Old Oct 26, 2011 | 05:54 AM
70buford's Avatar
70buford
Default 2004 350Z clutch question
Dealer says the flywheel is type the do not resurface......How often when a clutch is changed (i have 65000 miles)(seems to be self ajusted all the way to the end) has the flywheel been bad???
clutch $1400
clutch and flywheel $2660
Keith
Just looking for a ratio. one in a hundred, every fn' time
Old Oct 27, 2011 | 06:42 PM
holycrap's Avatar
holycrap
clutch $1400
Keith
$2660? for what kinda clutch and flywheel?
Old Oct 28, 2011 | 05:30 AM
Rob@Z1's Avatar
Rob@Z1
It is possible you need a new flywheel, but those prices are ridiculous! Our clutch/flywheel combo (lightweight flywheel) is only $659 with a SS clutch line, throw out bearing and pilot bushing. LINK
Goodluck!
-Rob
Old Oct 28, 2011 | 07:02 AM
winchman's Avatar
winchman
If the clutch is worn out but hasn't been abused, you can probably get away with using the original flywheel. Abuse would be letting the clutch slip for extended periods (which heats up the flywheel excessively) and letting the clutch disc wear down to where you have metal-to-metal contact and scoring of the flywheel. Both of these conditions will be obvious when you take the clutch apart, but knowing how you've treated the car will give you a clue on what to expect.
lolwatbro
Oct 9, 2021 04:58 AM
Ronso
Oct 30, 2015 12:39 PM
Thegad
Sep 11, 2015 01:35 PM
NYGiants0186
Sep 8, 2015 10:37 AM
