os giken with a/t gears issues
Old Nov 7, 2011 | 07:17 AM
NVRacing's Avatar
NVRacing
Default os giken with a/t gears issues
I ordered up a differential out of an auto g35 to take the ring/pinions out of and stick in my m/t rear end. I can see that the differential is larger from end to end on the a/t rear end, as well at the ring gear being thicker from side to side.
Trying to figure out how people get the 3.3 gear ratio in a m/t car with an aftermarket limited slip because the os giken diff would put the ring gear placement in the wrong spot for the a/t housing to work and the a/t ring gear is to thick for it to work in the m/t housing.
Are people machining the a/t ring gears to make this happen? Any help is appriciated.
Old Nov 7, 2011 | 10:23 AM
str8dum1's Avatar
str8dum1
You cant do it with an OS giken as far as I know. I think only Quaife and maybe one other company have a kit for a 3.3 FD
Old Nov 7, 2011 | 11:44 AM
NVRacing's Avatar
NVRacing
Wish the shop I bought the parts from wouldn't have recomended the a/t gearset...
anyone need a 3.3 fd?
Old Nov 7, 2011 | 11:49 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you need the OS for an automatic, or Quaife or Cusco also offer it
manual gears (3.5, 3.7, 3.9, 4.08, 4.3) go with manual transmission diffs, auto gears must use auto diffs
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
