Best DD clutch and flywheel
Old Dec 17, 2011 | 11:05 AM
khalafrommy17's Avatar
khalafrommy17
Default Best DD clutch and flywheel
Just curious to know what a good clutch/flywheel combo to go for.
2003 Z enthusiast
N/A. maybe putting some test pipes, y pipe, plenum spacer etc.. nothing over 375 HP.. main goal is to get a stiffness in the clutch but nothing to serous as it is my DD..
any suggestions from anyone with current set up?
Old Dec 17, 2011 | 11:13 AM
DK 350z DK's Avatar
DK 350z DK
Youre not going to get over 375 while N/A. So no worries there.
Old Dec 17, 2011 | 11:25 AM
khalafrommy17
yea never thought i would have. just threw a number out there that with the mods i wish to do, i'd still have some wiggle room which i figured to be 50 hp
Old Dec 17, 2011 | 11:37 AM
When your flywheel-clutch can no longer handle the awesome torque, lets talk about this. Until then you are fine.
Old Dec 17, 2011 | 11:53 AM
khalafrommy17
Originally Posted by davidv
When your flywheel-clutch can no longer the awesome torque, lets
i should of probably stated that my current clutch is feeling a bit mushy when engaging. thus the reason to change it.
"if its not broke don't fix it"
(i abide by this)
Old Dec 17, 2011 | 12:14 PM
hugo350z's Avatar
hugo350z
even after your clutch goes out stick with oem. The stock clutch can handle your power just fine. Also, if you wish to invest into a "better" clutch, keep in mind that clutch life won't be the same.
Old Dec 17, 2011 | 12:18 PM
(i abide by this)
How many miles on the OEM clutch?
Old Dec 17, 2011 | 01:31 PM
AngelsVQ's Avatar
AngelsVQ
jwt
Old Dec 17, 2011 | 03:15 PM
bbs350z's Avatar
bbs350z
^go jwt. if your clutch goes out, youd need a new flywheel because the oem dual mass is a piece of sheet.
jwt is street friendly holds tons of power will free up some power because the flywheel doesnt weigh as much as a fat womans cankle and its a proven setup
Old Dec 17, 2011 | 03:32 PM
khalafrommy17
95k miles. i am the third owner. i recently drove my cuz's 2006 touring and his clutch went in like butter, but mine is a little stiff. i'm thinking that my clutch may be aftermarket but not sure as thats the only other Z i have driven.
Old Dec 17, 2011 | 03:34 PM
khalafrommy17
lol. sounds good to me! is this setup a clutch and flywheel together? through some research to my understanding, separate pieces are rated better than the flywheel and clutch together... sorry for my noobness i may be incorrect on all this..
Old Dec 17, 2011 | 03:46 PM
resident25's Avatar
resident25
Most people on here go with the JWT clutch and flywheel combo including myself. Its a great setup and its quality has been tested time and time again. IMO, you should just get this, you won't be disappointed.
Old Dec 17, 2011 | 10:35 PM
Lightbulb
95,000 miles is definitely time for a new clutch.
Above: A clutch that looks like the OEM clutch will perform similar to the OEM clutch. Manufactures generally refer to this as Stage #1. You can also call to this clutch street friendly.
Above: Misinformed members often buy a clutch with a clamping capacity that exceeds their needs. Thinking is that if it can hold say, 400 pounds of torque, than it must be better. The result will often be an aggressive clutch that is a pain in *** to operate for a daily driver.
NOTE: If you are shopping for a flywheel and clutch, I recommend that you buy a flywheel and clutch from the same manufacture. They are designed and tested to work together.
Old Dec 18, 2011 | 08:42 PM
khalafrommy17
good stuff! thanks a lot!
Old Dec 19, 2011 | 09:32 AM
AngelsVQ's Avatar
AngelsVQ
correct.
i recommend the jwt because it is street friendly and fairly priced.
i personally have the competition stage 4 clutch/light flywheel. but im used to an aggressive clutch. no complaints here. *except in 101 traffic *
Old Dec 22, 2011 | 12:27 PM
juicenigk's Avatar
juicenigk
jwt clutch + light flywheel
just got this installed in mine and its very similar to stock and u can feel it accelerate quicker
775 in the vendors shipped
Old Dec 28, 2011 | 05:15 AM
Highway Riding's Avatar
Highway Riding
JWT \thread
Old Jan 3, 2012 | 04:30 PM
leo_giovani619's Avatar
leo_giovani619
JWT combo make sure to get all the parts.
Old Jan 3, 2012 | 07:08 PM
Dragonbreath's Avatar
Dragonbreath
Ill milliond the jwt setup.
Old Jan 5, 2012 | 07:29 AM
Michla22's Avatar
Michla22
bahhh I'm on my stock clutch from 2003 with 167,000 miles. Still feels / works great. Though I am going to finally cave this year and get a JWT Combo - I'm tired of hearing my throw out bearing squeal.
