Clutch/Flywheel install tomorrow.
Old Jan 30, 2012 | 11:53 AM
STL 350Z's Avatar
STL 350Z
Originally Posted by pbn85
ok so how about driving impressions? I bet the car almost revs up like a sport bike. I can't wait to do mine. What set up did you go with?
It's revs up considerably faster. I wouldn't call it sport bike though... it just has a lighter feel to the throttle. You mash it and it's effortless acceleration.
ACT Streetlite Flywheel and Exedy Clutch combo in the drivetrain vendor section. THMotorsports.
And if you do this yourself your going to need help and to read up on all the information here. I got lucky and didn't have to bleed my clutch and my shifter didn't need adjusting since I marked all the locations of the bolts holding the shifter in.
Good luck.
Old Jan 30, 2012 | 01:52 PM
Raybrant's Avatar
Raybrant
Just had mine finished up yesterday. Did most of the work Saturday but hit a brick wall when I couldn't get the tranny to line up and slide back in.
Definitely a pain in the ***. Jack stands are not the best way to go but if you are going to use them, have FOUR. It's not going to work well with just two jackstands as everything will be crooked and the tranny will not slide in and out right.
Also need a T-55 Torx bit for the flywheel. There's a locating dowel for the flywheels so remembering how it fits isn't that important, putting the new fw in is the more important part.
Old Jan 30, 2012 | 03:30 PM
STL 350Z's Avatar
STL 350Z
I hate those damn T55 torx bolts! Upon torquing them down one of them decided to troll me and strip out around 80ft-lbs. The rest took 90ish ft-lbs so...
Old Jan 30, 2012 | 10:59 PM
QuicksilverZ33's Avatar
QuicksilverZ33
I just did my JWT combo install yesterday and as far as torquing the flywheel bolts, I ordered new bolts from Nissan and torqued them to 70 foot pounds....I know the JWT instructions say 90 then re-torque to 93 but after doing some research I found that many people stripped them while torquing them that high. I just used the Nissan torque specs and re-torqued to 70 with red locktite. The service manual says 65.
Old Jan 31, 2012 | 05:59 AM
INTIMAZY's Avatar
INTIMAZY
There was a limited run of ARP flywheel bolts a few years back. They don't use that t-55, instead using a 12 pt socket. For future clutch swappers, they may want to call up and see if they can make more.
When I did a G35 install, I just used blue locktite and torqued down to 65 on new OEM bolts and it's fine.
Old Jan 31, 2012 | 07:31 AM
STL 350Z's Avatar
STL 350Z
I'm really wondering why I never thought about new flywheel bolts... I dont suppose one bolt being around 13lbs off will hurt anything. I hope...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
