new clutch install
Old Feb 25, 2012 | 05:58 PM
meanz's Avatar
meanz
Default new clutch install
So this starts out nice and fresh...motor out waiting for couple of upgrades including new clutch and flywheel. Taking out the clutch went flawless, its when i start taking out the flywheel when the problems start. I get every bolt out except one, the last bolt snapps. No problem right? The fly wheel still came off, so i try to clamp down on the bolt that is broken and twist it out....it snaps in half flush... no problem i will just drill it out..wrong! the bit just snaps in half lodging itself inside the hole. Its near impossible to drill out the drill bit stuck inside the hole. How bad is it if i cant get that bolt out? i Know its "bad" but how bad is it with 7 bolts instead of 8? im boosted with 420 to the wheels currently. Im not giving up on getting this last bolt out, but what if i cant get it out? Taking apart the engine to swap the cranks is almost not an option. This is such a pain, anyhelp is appreciated.
Old Feb 25, 2012 | 07:28 PM
AngelsVQ's Avatar
AngelsVQ
Ehhhh, because of the high speeds at witch it turns at I would think it would be a balance issue.
Old Feb 25, 2012 | 07:30 PM
meanz's Avatar
meanz
yeah i know, gonna go to work on monday and bring back some drill bits and see what i can do, something so simple turns into something such a pain
Old Feb 25, 2012 | 08:36 PM
suprasam's Avatar
suprasam
When I was still NA I had the JWT lightweight fly. A buddy of mine installed it for me but snapped one of the bolts but I did not have any issues with it. I know it's not scientific or technical. It's crazy that the flywheel bolts are weak enough to snap off.
Old Feb 26, 2012 | 06:14 AM
meanz's Avatar
meanz
well i got whats left of the bolt out, doesnt look pretty, have to redrill it out and rethread it.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
