"Shifty" Shifted Performance: My experience.
Old Apr 10, 2012 | 09:29 AM
  #41
Brew_haha's Avatar
Brew_haha
Have been following your build and this sucks to see. I knew there were some problems when i mentioned that the intake manifold looked polished and was meant to be chromed.
I saw that you were also having some problems with the racepack. If you need any wiring, AN fittings done correctly, or any cluster prices like stack or anything for that matter. I know you are prob not worried about some of the little things but if you need anything feel free to PM me.
Old Apr 10, 2012 | 09:33 AM
  #42
travismaser's Avatar
travismaser
MORE INFO: my custom drive shaft is about 2" too short!!! he had it just pulled out of the trans to make up for it... and all my power stearing lines were held on with water clamps...explains my leaks..and missing a nut on the turbo flange...pics to follow
Old Apr 10, 2012 | 11:02 AM
  #43
AngelsVQ's Avatar
AngelsVQ
what an ***, i feel bad for you man! wish i could hear his excuses, send him a link to this thread
Old Apr 10, 2012 | 11:23 AM
  #44
travismaser
hey guys! just so everyone knows...Stance monkeys on facebook is posting an article tonight about the whole situation (the owner of stance monkeys is the shop manager at shifted) please check it out!! i am actually really curious to see what is said on "the other side of the story"
Old Apr 10, 2012 | 11:32 AM
  #45
str8dum1's Avatar
str8dum1
i thought this was an established swap kit...?? Didnt realize your car was their 1st try.
Did DSS make the driveshaft?
Old Apr 10, 2012 | 11:47 AM
  #46
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Coming up later today will be one of the most personal articles I will ever have to write. I'd like everyone of my fans to read this one look at it watch the videos comment and share it everywhere you possibly can. I have watched slanderous childish boys run a muck on the forums and it is time that I write something back. So later today, everyone, please take 15 minuets from your day to read this.
Subscribing...
Old Apr 10, 2012 | 12:15 PM
  #47
wasuber's Avatar
wasuber
Wow Travis, sorry to hear and welcome to the club!
Move back to Washington, we don't suck over here
Old Apr 10, 2012 | 12:25 PM
  #48
Highway Riding's Avatar
Highway Riding
Gotta Love NJ mechanics.... This is why i took my S14 to PA (Import Intelligence) for my motor swap.. 3 oil changes and 6400 miles later and I'd do it again and would advise guys to use them!
Old Apr 10, 2012 | 12:35 PM
  #49
bigcloud's Avatar
bigcloud
Old Apr 10, 2012 | 12:46 PM
  #50
pmab9918's Avatar
pmab9918
Originally Posted by Quamen
They built a custom single turbo for me and blew my engine up and ruined a lot of things on my car. They also bought eBay cheap stuff when I paid for name brand. This was also when a used motor was $6,000. Cost me just shy of $30,000 to repair and get back to a beatup stock car since the car was still fairly new and parts were expensive.
Bottom line is that without perfect documentation of the agreement it is near impossible for a judge to make an impartial decision. Add in that there is no true benchmark for this swap to use as a comparison against. Labor deals where you also get half off make the case even shadier unless there was documentation as to the standards that would be maintained. The op will be hard pressed to collect money even if he did win.
Wow man, sorry to hear that...
Old Apr 10, 2012 | 12:52 PM
  #51
graffkid732's Avatar
graffkid732
Originally Posted by SuperBlack350z
you said 16k in a build, he gave you back half of labor, which is 2k. labor is only 4k. so basically, you aren't out as much as you make it seems. good luck on your future build. that shifter is just horrible.
Well since he spent say 16k and they messed up in multiple ways, yes he is out more than just labor. He now has to replace parts that shouldn't have to be replaced, and still out the 2k for labor fees.
Old Apr 10, 2012 | 12:54 PM
  #52
travismaser
new pics of the motor being pulled out!!
b4 the pics...here is a quick list of things to look for
-driveshaft about 2 inchs too short
-water clamps on power steering lines (was loose and leaking)
-missing nut on turbo flange (was i guess too hard to get too)
-exhaust manifold was missing 2 bolts, 2 of the remaining were loose
-5 different types of bolts on trans mount
-onlu one bolt, ONE, on the pass side of the transmission holding the trans to the trans mount....the one on the drivers side was missing
-missing 2 bell housing bolts
-heater core clamps were finger tight
-radiator drain was finger tight (no idea how this didnt leak)
-when pulling motor, the passenger side motor mount FELL OFF! the drivers side was loose and only held on with 2 bolts
on to the pics:
the JB welded fitting pulled out
for a i guess, cleaner look...he drilled out the rivet in the VIN tag to run a zip tie thru to hold the breather lines
he made sure he had that exhause as tight as possible didnt he!
my power steering leak
this is where the drive shaft fits in the back of trans...this is how short it is...i think his measurments were a little off???
fuel lines zip tied to sub frame...sube frame was missing a bolt
zip tie attached to t-bolt clamp holding inner fender well up
this isnt THAT bad..but could have been cleaner...cut the bumper support up
fans were not mounted, at all...just wedged in there
missing nut on manifold to turbo
guess this explaines why my EGT's dont work
missing starter bolt
THIS MADE ME WANT TO CRY!!!i paid $220.00 for this shifter extension!!! broken then JB welded!!!
missing bolts from mounts to motor
on both sides
bolt block off...
this is what held the trans to the trans mount...this ONE bolt (that was loose)
got a new socket out of the deal!!! wooo
AND LAST BUT IM SURE NOT LEAST!!! (still have to look inside yet)
crack in my "new" 1jz flywheel
Old Apr 10, 2012 | 01:10 PM
  #53
davboy's Avatar
davboy
How did this guy have any pride in this car to sign it? Sorry man but they turned your car into late term abortion. I wouldn't let him put air in my bicycle tires, and I don't own a bicycle. I hope something good comes of all this BS.
Old Apr 10, 2012 | 01:17 PM
  #54
pmab9918's Avatar
pmab9918
Jesus, do these shops think that people will not look at their cars once "completed" wtf!
Old Apr 10, 2012 | 01:28 PM
  #55
clarkah's Avatar
clarkah
Can't wait to read the owner side of the story..
Old Apr 10, 2012 | 01:46 PM
  #56
Duckeee's Avatar
Duckeee
almost worse than tapping wood screws to install side skirts
keep your head up high travis sir.
Old Apr 10, 2012 | 01:54 PM
  #57
stogey420time
Club Moderator
the Hot Spot
Shifted Performance just got done writing a book, telling their story 10mins ago...
http://www.facebook.com/Shiftedperformance
Old Apr 10, 2012 | 02:11 PM
  #58
OCMan's Avatar
OCMan
some of Shifted Performance's other side of the story doesn't make any sense.
Old Apr 10, 2012 | 02:26 PM
  #59
ace32x's Avatar
ace32x
wow that book they posted was a joke lol. some one should copy some of these pics into it haha
Old Apr 10, 2012 | 02:31 PM
  #60
jerseystyle's Avatar
jerseystyle
I can't believe some of the BS excuses they gave. All I can say is WOW!
