Problems after clutch and flywheel install
Old May 11, 2012 | 02:01 PM
driftk1d's Avatar
driftk1d
Default Problems after clutch and flywheel install
I recently installed a competition clutch and lightweight flyweel but as well as changed my oil and cleaned my air filter with k&n air filter cleaner.
I test drove it last night and everything seemed fine but this morning on the way to formula drift my tach started bouncing up and down as I accelerated and it started idling rough. It idles rough and sounds horrible. Any idea what it could be? I cleaned the maf and I'm looking to see if I pinched any vaccume lines. Any ideas of what could be causing this?
Old May 11, 2012 | 02:18 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Crank position sensor. Uses the flywheel. You may have damaged that sensor.
Old May 11, 2012 | 02:44 PM
driftk1d's Avatar
driftk1d
I removed it during my swap and kept it in a safe place. Then I put it back in after everything was bolted up. Is there any way to put it in wrong?
Old May 11, 2012 | 06:40 PM
Mint Racer's Avatar
Mint Racer
did u place the pin on the back of the flywheel in the correct hole, its a common mistake.
Old May 11, 2012 | 07:02 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
^^ I'm using this line next time with the lady (thread jack, sorry)
Old May 11, 2012 | 08:29 PM
AngelsVQ's Avatar
AngelsVQ
im sure its the maf, did you use to much cleaner/oil on your filter?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sherm
Apr 11, 2020 05:21 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
