The problem with catch cans and the 350Z
Old May 27, 2012 | 01:40 PM
  #41
binder's Avatar
binder
Originally Posted by F2CMaDMaXX
2) It vents to atmosphere, the air is metered, i needs to go back in the engine.
You do realize that catch can opened to the atmosphere does NOT interfere with metering?
The plenum is blocked off so no outside air is getting in. If the air in the crankcase leaves the crankcase it does NOTHING to the maf signal at all. You are confused with having a vac leak on the intake side with having open breathers on the crank case.
The crank is producing positive pressure so it will always be pushing gases out and never sucking them back into the crank case. Even if it did suck air into the crank case that air would not be drawn into the intake anyways so it would never cause a problem with maf signal.
thousands of cars have open breathers and it does nothing to the metering at the MAF. Just about every car on the market has a maf and most builds for high hp use open breathers for less crank pressure.
oh, and you didn't look hard enough. Boosted performance makes one as well that bolts onto the front cover of the car to sit right between the 2 timing covers.
Old May 27, 2012 | 07:40 PM
  #42
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yes, my can shipped out friday, so i'll let you all know with some pics when i get it.
The link to that $95 shipped can looked like a reasonable design, hopefully this 350z can will be cheaper and be ready to fit
Old May 27, 2012 | 07:44 PM
  #43
bmccann101's Avatar
bmccann101
Returned the can I had..bought two new ones w removable tops... used perforated vinyl tubing on the in side of the cans. Bought Poly scrubber's versus the steel .. they look pretty robust. I'm hoping they'd be fine. So two cans for under 70 bucks in parts...500whp set up..anyone know ( not just think ha) of reasons these will not work?
Old May 27, 2012 | 08:26 PM
  #44
F2CMaDMaXX's Avatar
F2CMaDMaXX
They sound good to me.
Old May 27, 2012 | 08:52 PM
  #45
F2CMaDMaXX's Avatar
F2CMaDMaXX
Sorry, must have missed the Boosted performance can, only it's over $185 shipped and vents to atmosphere, which were two of my original points.
Not sure that's the best baffle system, can't see why pipes come out same side, but at least it's baffled and it was made to fit the 350, so nice
Refer to the post from the LS1 forums a few posts up as to why you don't want to 'open air' the stock closed PCV system.
These systems are designed to work closed, they're not like the old American systems running either draft or open PCV systems.
The air passes the MAF, and some is syphoned off and heads into the crank case. This then gets put through the PCV valve and back into the intake.
If you then have that air no longer going back into the engine, then you're missing air that was metered. It's got nothing to do with outside air getting it, it's all to do with removing air from the system that was metered before it got into it.
It doesn't matter if engines *work* with that setup, they're not working *correctly*
Old May 27, 2012 | 09:28 PM
  #46
SDGenius's Avatar
SDGenius
i run a Saikou Michi Stage 1 can, great quality product
Old May 27, 2012 | 09:49 PM
  #47
F2CMaDMaXX's Avatar
F2CMaDMaXX
Would love to see your mounting method there, Saikou Mitchi is sending me the micro can to fit a little nicer.
Old May 28, 2012 | 07:08 AM
  #48
binder's Avatar
binder
the ONLY reason it is designed as a closed system is emissions. That is it 100%. It has nothing to do with performance. In actuality it actually decreases performance because it's burning some vaporized oil which will gum up intakes, valves, and spark plugs.
I've logged and watched the maf signal and tune going from fully closed to an open breather system and it affects metered air zero. The only way metered air is changed is if fresh air is introduced into the intake after the maf. If you have a closed intake system (no pvc attached to it) then nothing is going into the intake. On top of that the crankcase is always pushing air OUT from the catch can not sucking air in. So there is no way for air to actually get back into the intake from the outside.
hook up some vac lines to the catch can and do some logs. It is never pulling fresh air into the crankcase and even if it did the air from the crankcase will not magically get into the intake system unless it's somehow forced up the crankcase and past the piston rings.
I'm not sure how you think fresh air is getting back into the intake from a crankcase breather. It just doesn't make sense. The intake system after the maf is sealed off in an open breather system. You can close off the open breathers and nothing changes in signal, open them up while watching the logger and nothing changes. Maf signal, a/f, trims, etc all stay the same.
Old May 28, 2012 | 12:10 PM
  #49
F2CMaDMaXX's Avatar
F2CMaDMaXX
I agree that's the main reason why it's designed as a closed system, but if you look on the links i posted a page back, you'll see it actually has other advantages running as a closed system (other than emissions)
The reason we're running catch cans is to mitigate the 'gumming' issue.
This is correct, in that you don't have air going back to the intake. However, you have to remember that the PCV is an enclosed one way (for the most part) system:
Here are the paths that air takes.
Intake > MAF > Plenum > Cylinders > Exhaust
(Also the blowby route can include from cylinders > Crank > PCV valve > Plenum)
Intake > MAF > Crank intake > Crank > PCV valve > Plenum (cycle)
Either way, all the air that is metered, goes through the engine one way or another, and that was my point, it's expecting that and is getting that.
This is backwards, so you're right, it's not doing that.
Again, correct, it comes from the crankcase, and enters the intake system at the plenum again. All the air, be it blow-by or intake sourced, all came through the MAF first.
Old May 28, 2012 | 12:33 PM
  #50
Stock2Autocrozz's Avatar
Stock2Autocrozz
I am intrigued by new cans lol
Old May 28, 2012 | 12:54 PM
  #51
Ronin82's Avatar
Ronin82
this thread is giving me all kinds of ideas.....
Old May 29, 2012 | 05:29 PM
  #52
F2CMaDMaXX's Avatar
F2CMaDMaXX
So the new can is here...
Problem is, i'm full of mail-fail today it's currently locked in the office until tomorrow, i'll get as much taken/posted as possible in the next two days.
Old May 29, 2012 | 07:26 PM
  #53
djamps's Avatar
djamps
+5 chuck norris's for the sticker.
Old May 30, 2012 | 05:30 AM
  #54
binder's Avatar
binder
I'm confused why running an open breather wouldn't cause any change in engine logs if that air that comes from the crankcase isn't re-circulated. If the engine is negatively affected by not recirculating the air that passes the maf then it should have a change when it is vented to atmosphere. Based on logs it doesn't change a single thing going from re-circ to open.
The bolded path above. Where is that path on our engines? Our drivers side port is attached before the maf and will pull crank gases out of that bank via vacuum when driving and the passenger side vents to the plenum like the first path you listed. I don't see a path from post maf directly into the crankcase on our cars.
Old May 30, 2012 | 11:51 AM
  #55
F2CMaDMaXX's Avatar
F2CMaDMaXX
I may be wrong here, but there is no tube on the intake that comes off before the MAF. The MAF is right next to the air filter at the start of the intake tract.
Secondly, the "intake tube to drivers side port" is not pulling air from the crank, it's allowing air to travel into it. The pull from the plenum to the PCV valve (passenger side) causes it to travel in that direction.
Old May 30, 2012 | 12:05 PM
  #56
ronn1's Avatar
ronn1
I had a catch can on my Cobalt Turbo...didn't catch much. It vented back into motor. Maybe I'm off base here, but I see NO REASON to use one in this car if it's NA. You're in Vacuum all the time..no positive intake pressure. My HR burns/ uses almost ZERO oil over 6k mile OC intervals (1/2 Qt).
Old May 30, 2012 | 12:23 PM
  #57
SDGenius's Avatar
SDGenius
^have you ever seen the inside of a DE plenum? a lot of oil vapors get circulated in
Old May 30, 2012 | 03:40 PM
  #58
jerryd87's Avatar
jerryd87
what binder is saying is the same thing i was saying. both ports are seeing the exact same amount of vacuum so while the fsm might say thats how it works it dosnt, for the system to work like how honda and nissan say it does would require it to defy the laws of physics and fluid dynamics. i understand how nissan is saying it works and i see what you think it makes sense, vacuum at pcv causes everything to be pulled in from the other back port on the valve cover but it dosnt work that way because that port see vacuum as well. the picture in the fsm that shows it pulling from the pcv and the drivers side valve cover at the same time is the only way the system will work. the only way any air is going to go into the crankcase from the intake is if your boosted.
like i said the only way for it to work with pushing air into the crankcase with vacuum would be a high pressure area in the intake that would lead to the port on the intake for the drivers side valve cover. which would require fast moving air and putting a wall in the airflow, which the intake dosnt have. the car has 0 ways for air to be pushed into the crankcase. the fsm is wrong, and if you think that theres no way nissan can be wrong because they make the car and are a large manufacturer then go try and get a bosch oil filter for our car, large auto manufacturers make mistakes all the time. my guess is that is in referance to another vehicle that has a vacuum pump on it so it works that way or turbocharged vehicles. the fsm also makes mention about turbochargers precautions which our vehicle does not have from the factory(and the system would actually work the way they describe it if it where turbocharged.)
bottom line bro is the fsm is wrong in many many many places. just because a book says something works some way dosnt mean it can defy physics and fluid dynamics. im guessing you will find that same diagram on every single nissan vehicle.
Old May 30, 2012 | 06:08 PM
  #59
F2CMaDMaXX's Avatar
F2CMaDMaXX
It's all dependant on engine wear, driving conditions and mileage of the engine. But ordinarily, you're right, N/A's do not produce the same as Turbo setups.
Old May 30, 2012 | 06:24 PM
  #60
F2CMaDMaXX's Avatar
F2CMaDMaXX
How so? The PCV side has vacuum from the intake, behind the TB, it's constant and heavy.
The drivers side just has the intake air blowing that way.
Independent PCV articles show the same thing, seems no one shows it the way you're describing.
I do however think, that i know what you're saying about the intake pipe, wind rushing past the end of it should technically create a vacuum at the intake tube end. However, it has to suck air from somewhere, the PCV valve is one way, so it can't travel that way.
Plenum pulls from the PCV side/passenger side.
Engine pulls from the drivers side/intake tubing. The system is sealed, the intake speed would have to create a vacuum waaay more powerful than the one the plenum is creating (on the other side) for it to be flowing back into the intake tubing.
You don't get oil on the front side of the butterfly, just the back side.
.... the car has 0 ways for air to be pushed into the crankcase. the fsm is wrong, and if you think that theres no way nissan can be wrong because they make the car and are a large manufacturer then go try and get a bosch oil filter for our car,
It's unlikely to be pushed, now you make me think about it, see last comment i made as to how that flows.
Not really sure what you mean about buying a Bosch oil filter, i use them all the time...
.... im guessing you will find that same diagram on every single nissan vehicle.
Yeah, i would imagine it is, they all use the same system, nearly (if not actually) all modern cars use the sealed PCV system.
