Proper A/F ratio??
Old Jan 5, 2004 | 07:44 AM
350Z_Redline's Avatar
350Z_Redline
Default Proper A/F ratio??
What should a properly tuned A/F look like for a modded N/A Z? I'm talking from like 1k-redline @ WOT. It seems that everyone is only concerned about what the A/F looks like after ~4k. If I had my A/F tuned to 12.5 from 1k-redline would this be good or bad? I've been told that it should be 14-13.5 in the lower rpms @ WOT and ~12.5 after 4k. Is this correct? Should it be a little learner in the lower rpms @ WOT?
Old Jan 5, 2004 | 01:52 PM
failsafe's Avatar
failsafe
....for your health
The main concern is at higher RPM's (above 4K). After I installed the RT cats (w/ TS ECU) I was running 13.6 at about 5000 and had some minor, but audible, pinging. I had TS reflash and I'm now about 12.6 at 5000 and pinging is gone.
Old Jan 5, 2004 | 02:51 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I hve the very same concern. My car is not running nearly as we;ll as it should be. I raised this very same concern (for the lower rpm A/F's) to improve my lower end. Doug of Crawford Z Servce told methat you DO want the lower end rpms be closer to the stocihiometric ratio - in the 13's. and it should taper off to about 12.8.
I would really love to see a discussion about this.
Gurgen
etkms
Jun 19, 2022 06:30 PM
m_0g
Jun 3, 2021 10:05 AM
Depravity
Oct 1, 2015 04:49 PM
FromGtoZ
Sep 20, 2015 03:41 PM
