lsd
Old Jan 8, 2004 | 06:07 PM
philsill350z's Avatar
philsill350z
Default lsd
what will my disadvantage be for performance on the 1/4 mile without having a lsd rear. and where would i find a cheap rear?
Old Jan 8, 2004 | 06:18 PM
FLY BY Z's Avatar
FLY BY Z
traction
junkyard?
or do you mean a cheap lsd? froogle.com?
Old Jan 8, 2004 | 06:52 PM
Gsedan35's Avatar
Gsedan35
Default Re: lsd
I can't really comment on the 1/4 part of your question, but I can sure say something about the cost of doing OEM LSD conversion.
I could not find a whole rear diff to simply swap. Instead, I managed to find a viscious unit itself with NO miles for $100 In order to swap that into a NON VLS (Viscious Limited Slip) rear end you have to add these parts. LSD bearing set and seals $100, stub axle's ment for a LSD equipped car $300. Add $400 to do all the disassembly and reassembly and my total cost was $900 and that's if you can can the oem unit for $100 or the whole LSD diff for $500. Frankly, if you get the Nismo LSD for $900, it comes with those bearings and stub axles, saving you $400 in extra parts. When I went to the dealer to do the swap, I did not know that I've have to buy and install those $300 stub axles. Had I known in advance that my final cost was going to be $900, I would have done the Nismo LSD route instead. Clutch type LSD is more effective than VLS.
Old Jan 8, 2004 | 06:55 PM
350zdanny's Avatar
350zdanny
Nismo LSD also allows you to change the lockup without disassembling the unit, doesn't it?
Old Jan 12, 2004 | 05:42 PM
VQ35DES's Avatar
VQ35DES
bump
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
