Final Drive Install Help?
Old Aug 9, 2012 | 11:28 AM
xslangx's Avatar
xslangx
Default Final Drive Install Help?
Any write ups on how to swap? I can find how to swap differentials but not the final drive...
Any links would be great! I'm attempting to do this myself so it would save me $ and time if you could help!
Many thanks,
JC
Old Aug 9, 2012 | 02:14 PM
Duckeee's Avatar
Duckeee
unless you have some experience in that gray area, i'd advise to get it professionally done.
pumpkin chunkin
Old Aug 13, 2012 | 12:03 PM
starvinmrvn's Avatar
starvinmrvn
what did you decide OP? DIY or hire someone? Just curious...
Old Aug 19, 2012 | 04:59 PM
xslangx's Avatar
xslangx
245$ for a local shop to do it, I just need to run to dealership same day and pick up shims!
will be a 2 day downtime though ...
Old Aug 19, 2012 | 07:54 PM
solrchrgd's Avatar
solrchrgd
Default What shop?
Just curious which shop you chose? I am looking to get my 4.083 and quaife LSD installed very soon.
Old Aug 19, 2012 | 10:28 PM
AnnLindel's Avatar
AnnLindel
Old Aug 23, 2012 | 04:37 PM
GunslingerG34's Avatar
GunslingerG34
Any trained monkey can slap in a R&P set, but properly setting up a differential is an art, and I've found VERY few shops that know how to do it right. If you are not extremely mechanically-oriented and well-trained in building rears, I'd definitely pay the $$ to get someone reputable to do it. It'll save you a lot of money and frustration in the long run!
Old Aug 24, 2012 | 03:07 AM
ian99rt's Avatar
ian99rt
Dont bet on the required shims being in stock at the dealership or the supplying warehouse. I had a 3 months delay waiting for the correct shims when I setup my quaife and FD..
Old Aug 26, 2012 | 12:37 AM
juicinjake's Avatar
juicinjake
oh god... im getting ready to do this install myself and i just read this. i hope i dont get stuck with the same luck on my quaife and 4.083 fd install. where did you end up having to get the shims from?
Old Aug 26, 2012 | 01:18 AM
terrasmak's Avatar
Go to a reputable driveline shop , they one I use in Vegas builds diffs day in, day out. Both times I got my 3rd member back the next day.
It was $175 for my diff install , $225 for my 3.7 gear install a few months later.
Old Aug 26, 2012 | 05:43 AM
ian99rt's Avatar
ian99rt
Shims were ordered thru courtesyparts.com but there simply wern't any in the country at that time.
I built mine on a spare pumpkin i bought for $150, which was great because i had no down time but also led to procrastination because I could have made my own shims at work.
If you can find a shop (maybe Terrasmark's place does this) that has a lathe and a precision surface grinder, they could make you the required shims if they are not available....
Old Aug 26, 2012 | 05:53 AM
redline06's Avatar
redline06
lol im so glad my quaife and 4.08 combo didnt need shims other than stock. i did everything myself except the pinion press and torquing of the rear seal thing. $100 and the dude just went ahead and installed the rest of it so i just had to put the heavy a$$ diff on ther car. the guy supposedly really knows his $hit when it comes to differentials, year and a half later with no problems. Solid diff mounts going in wednesday FUN!
Old Aug 26, 2012 | 06:53 AM
e30cabrio's Avatar
e30cabrio
I had mine done at a shop and a year later it ate it's self. Cost me 300 labor and 5xx.x for a new ring and pinion over the initial cost.
I strongly suggest having it done at a qualified gear shop.
Old Aug 26, 2012 | 07:03 AM
P&K350Z's Avatar
P&K350Z
This.
Setting gears is more art than science.
Mattg350z
Oct 2, 2015 06:51 AM
samansharif
Sep 25, 2015 12:31 PM
