Fidanza Flywheel & ACT Street Clutch / Pressure Plate
Old Sep 5, 2012 | 04:54 AM
maxpusher's Avatar
maxpusher
Default Fidanza Flywheel & ACT Street Clutch / Pressure Plate
Hello,
I recently changed my flywheel, clutch, and pressure plate due to wear with a Fidanza flywheel and ACT performance street clutch and pressure plate. Compare to stock, the new combo grabs better and is not that much noisier. The clutch point is a little below stock.
However, the clutch pedal is MUCH stiffer than stock. I wanted to know if the stiff pedal was normal, and if others were experiencing the same. I am hoping this will subside once the combo is broken in. I would like to hear opinions. Thank you.
Old Sep 7, 2012 | 06:29 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
ACT clutches are normally pretty heavy at the pedal, Most likely will not get any lighter, You may get use to it in time though.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
