The 1 Billionth Transmission/Clutch Noise Question
Old Oct 8, 2012 | 06:02 PM
sporkdevil's Avatar
sporkdevil
Default The 1 Billionth Transmission/Clutch Noise Question
** Checked multiple threads. If this has been answered 1,000 times then I blame the search function **
I've had my 35th anniversary edition for 5+ years and have put about 45K-50K on it (now has 65K miles) and am well used to noisy 6 speed. However, a few days ago I gave the Z a spirited run through a few red line shifts and have since been getting intermittent metallic grinding noise/vibration right at the point of engaging/disengaging the clutch. This is no normal/usual noise and is fairly loud and pronounced for the brief moment of putting in/out the clutch.
Seems to come up when the engine is warm and more noticeable in lower gear. Asking because I need a few more days until I can get off of work and get it to a shop and don't want to be doing any major damage to the transmission before that point if I don't have to.
Old Oct 8, 2012 | 06:36 PM
djamps's Avatar
djamps
It's noisier when the fluid heats up (and thins out). When I'm at the track it's noisy as hell after a few laps even when putting around in the lot, but on normal days and cooler weather it quiets back down.
Old Oct 8, 2012 | 07:27 PM
Italianjoe1's Avatar
Italianjoe1
Sounds like the clutch release bearing is starting to fail.
Obadabot
Jun 18, 2023 11:31 PM
issyz
Jul 2, 2017 03:04 PM
