Optima Lightweight Battery Installation
Old May 22, 2004 | 08:34 PM
  #41
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Very good thread...
Old May 22, 2004 | 10:21 PM
  #42
Apexi350z's Avatar
Apexi350z
Charter Member #50
Originally posted by Brad4rdHay
Installed!
Instaled it today. Fits perfectly if you modify the bracket slightly.
I think I could actually feel a diference. Pulling a hard right our of my driveway as I do every morning, the car feel a little lighter on it's front tires this time. Acceleration is slightly (read slight) better. But hey, also peace of mind knowing that heavy *** (and man is it heavy) OEM battery is out of there.
I thought you installed back on 1/21/04?
Old May 23, 2004 | 12:29 AM
  #43
apsilon's Avatar
apsilon
Anyone know the CCA and Ah ratings of the stock battery? I was looking for them today on the battery and couldn't see them. I'd like soemthing with more reserve as my alarm drains the stock one within a week if I'm not careful and I have a feeling the stock doesn't like even this amount of cycling.
EDIT: Jeff, which battery is the SC51RDA on the Optima site? It doesn't appear to match up with the models they have listed. Thanks.
Old May 23, 2004 | 06:02 PM
  #44
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Jason, my battery failed on me. It lastd about 3-4 days, then died. CHarged it, put it back in, then it dies the next day. Instalation was perfect....was it a defective battery?
Do you have any audio mods? or anything electrical in your car?
I will find out the CCA and Ah ratings on the stock battery monday...
Old May 23, 2004 | 09:34 PM
  #45
DaveO's Avatar
DaveO
Here's the two batteries I'm considering... someday.
Optima Group 51R "Reversed" Yellow Top "DEEP CYCLE"
Cranking Amps- 625
Cold Cranking Amps- 500
Reserve- 70
Dimensions are 9.2"x 5"x 8.9"
Weight is approx. 27 lbs.
Battery has Top Post only with handle for easy installation
Optima 34R Orange Top (Top is now Red)
Cranking Amps- 980
Cold Cranking Amps- 800
Reserve- 110
Dimensions are 10"x 6.8"x 7.8"
Weight is approx. 38.8 lbs.
Battery has Top Post only (Reversed Terminals) with handle for easy installation
DaveO
Old May 24, 2004 | 09:40 AM
  #46
mysilverz33's Avatar
mysilverz33
Originally posted by Jeff@Performance
Wow, your poles are reversed. For the 350Z, you need the SC51RDA and you won't have to mess with the cables as they will go right on. Here's a pic of my car...
His poles aren't reversed, you just turned your battery around the other direction.
Old May 24, 2004 | 02:05 PM
  #47
ChuckGZ's Avatar
ChuckGZ
yeah, i thought i was the only one who noticed that.
Old May 24, 2004 | 05:50 PM
  #48
apsilon's Avatar
apsilon
Have a look at the photos again. One of them is the reverse of the other. In both pics the posts are closest to the camera yet one has the positive on the right while the other has the positive on the left. If you turn the battery around the posts will be at the rear, further away from the camera and you'd probably have the same reach problem with the cables.
Old May 24, 2004 | 07:43 PM
  #49
can350z's Avatar
can350z
Default More info....
This page has more info....
Red top also has a 28 lb version...
http://www.ajusa.com/cgi-bin/optima/...verture-optima
Old May 28, 2004 | 12:11 AM
  #50
shortcut3d's Avatar
shortcut3d
I just installed the Optima Yellow Top 51R. I got from the stereo shop where I had dynamat and vblock installed. I go with the philosophy of weight in / weight out, so it was a must buy after reading this thread.
The stock Bose sounds much better with the Nissan Motorsports grounding kit, dynamat and optima battery.
I just wanted to know the stock battery specs.
Old May 28, 2004 | 05:20 AM
  #51
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Part# 999M1-NB35C
Weight 39 lb's
Group 35
CCA 575
RC 100
18 month free replacement
60-month limited warranty
Dealer cost $49.95
List price $69.99
Your price $55.00
Old May 28, 2004 | 08:17 AM
  #52
shortcut3d's Avatar
shortcut3d
Default Misleading Thread - Setting it straight
Part# 999M1-NB35C
Weight 39 lb's
Group 35
CCA 575
RC 100
Dealer cost $49.95
List price $69.99
Your price $55.00
If the Optima battery weighs 27lbs and OEM is 39lbs the weight savings is only 12lbs. Not 22lbs for everyone who is claiming this. Also the Optima 51R is not equal or stronger than the OEM battery. The Optima 51R does work and save weight. It provides more consistent power as well. For $129.99 is it worth it, no. The 34 series Red Top Optima is better choice when power is required.
All that said, I'm still keeping mine. Just a little upset about the quoted weights.
Old May 28, 2004 | 09:41 AM
  #53
jrotaryb's Avatar
jrotaryb
If any of you can feel the difference in acceleration from a lightweight battery you should committ yourselves to a local institution right now bc you are craaaaaaaaaaaaaaaaaaazy
Old May 28, 2004 | 11:25 AM
  #54
Jeff@Performance
Performance Nissan
Default Re: Misleading Thread - Setting it straight
This may be partly my fault. The stuff I quoted above was for a Nissan factory replacement battery. I do not have a stock one out of a car on hand. I think the stock original battery may weigh more!!!
Old May 28, 2004 | 11:33 AM
  #55
shortcut3d's Avatar
shortcut3d
I don't doubt that the replacement that you are quoting could be different from the stock battery.
Is the replacement battery dry and/or maintenance free like the Optima battery?
I was very disappointed that the factory Nissan battery in their flagship car is not maintenance free. When I saw the fill lines on the factory battery, I decided that it was going to stay out. The weight savings, CCA, CA, etc. does not mean much when you have a cheap POS factory battery that should have never came on the car.
Old May 28, 2004 | 12:19 PM
  #56
Jeff@Performance
Performance Nissan
Replacement "FACTORY" battery is made by Interstate Battery, to Nissan's spec's and badging. It is a wet type battey with caps that pop off the top for maintainance.
Old May 28, 2004 | 03:04 PM
  #57
apsilon's Avatar
apsilon
Any luck with the stock battery CCA and Ah ratings? Alternatively the Ah rating for the replacement battery listed above (I'm assuming the replacement is better than the stock which is the usual practice).
Old May 28, 2004 | 05:50 PM
  #58
ZU L8R's Avatar
ZU L8R
Viper Sellout
Default Re: More info....
So the SC51DA is the lightwieght red top we can get? Are the poles on the correct sides?
Old May 29, 2004 | 10:48 PM
  #59
Tex Willer's Avatar
Tex Willer
Originally posted by trackstar
At some point, I plan on putting an Odyssey battery in. 15 lbs for $85? What is the stock battery, 45 lbs? Can't hurt to lighten up the front end
http://www.odysseyfactory.com/default.htm
according to stock that battery is seriously under spec.
Old Jun 25, 2004 | 01:00 PM
  #60
Apexi350z's Avatar
Apexi350z
Charter Member #50
I just installed the 51R Yellow top Optima Battery.. I weighted both batteries..
OEM = 36lbs
Optima=26lbs
Total saving = 10lbs..
There you have it!
Other than that, the starting (cranking) power seems to be similar... I will definitely keep the Optima battery because it will last longer than the factory battery..
