Oil Catch Question
Old Nov 20, 2012 | 07:39 PM
binder's Avatar
binder
Originally Posted by MouseTrap
hah 90-95 for 2 hours count as highway driving? I need to log a bit more. See where my temps are actually at before I start getting too involved with the cooler. I know they are up there though. Last time I had it hooked up I remember it being well over 200. Im definitely curious now as to how high they peak at.
Not sure what you were logging because there isn't an oil temp sensor on these cars.
Maybe coolant temp. Rad fans don't kick on until 210 so seeing over 200 isn't that big of a deal.
90-95 in vacuum isn't load at all. 16lbs of boost and 100% throttle for 45 minutes straight is hard load. The coolant temps will probably still run 180ish running that fast on the highway due to all the airflow and still very low load on the engine.
Old Nov 27, 2012 | 10:38 AM
MouseTrap's Avatar
MouseTrap
Youre probably right... It may have been the Subaru. That was at 21lbs and cooked oil like crazy.
Once I get the can installed Ill be able to draw more conclusions about my oil situation. Just havent had time with school and work
burglapfd
Dec 6, 2020 01:04 PM
issyz
Jul 2, 2017 03:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
