Monitor Engine Parameters
Old Jan 14, 2004 | 03:49 PM
Murry's Avatar
Murry
Post Monitor Engine Parameters
For those of you interested in data loggers for stuff like Throttle position, O2 sensor, Fuel trim, engine codes, load, etc. check this out.
Pocket logger website
BTW After I read a post about the possibility that the throttle doesn't open all the way on the 350Z, I was reminded of something a dyno operator told me. He said that a simple , but little known, performance mod for the 300ZX was to adjust the throttle linkage to allow it to open fully-which it apparently didn't do from the factory. Don't know if its true but food for thought.
Old Jan 14, 2004 | 05:21 PM
KJY9's Avatar
KJY9
Default Re: Monitor Engine Parameters
Since the 350 has an electronic throttle, that's not going to work on our cars, but if you get your ECU flashed, they can fix that in a heartbeat, or so I'm told. I'll know tomorrow night after mine's done at Fisher Speed
Old Jan 14, 2004 | 06:47 PM
jjellyneck's Avatar
jjellyneck
Default Re: Re: Monitor Engine Parameters
Oooo. I'll be scouring the forum for your post on the results!
Old Jan 14, 2004 | 07:42 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
pocketlogger is not adequate for teh 350Z....v e r y s l o w r e s u l t s
but Mike builds a great product for the DSM's and other cars, jsut too slow on some cars like the Nissans and Subaru's.
Old Jan 15, 2004 | 09:26 AM
azrael's Avatar
azrael
I'm currently designing a real engine datalogger to log a wide variety of engine parameters to an RS232 data stream. It doesn't use OBD-II.. it uses its own set of sensors to read
EGT x 2, IAT, TPS, Oil Temp, Coolant/Water Temp, Oil Pressure, Fuel Pressure, Boost, RPM, Speed, etc, etc.
I'm currently in the design phase. When it's done, it should be able to log all those parameters and more between 50 and 100 times per second to a laptop, which can then display/analyze the data, or export to Excel or whatever. Eventually I'm hoping to link the engine data to a GPS data stream, so you can read engine parameters as they relate to your position on a road course.
If there is sufficient interest, I might market the datalogger and associated software when I'm done.
Old Jan 17, 2004 | 02:58 AM
THX723's Avatar
THX723
This may be a dumb question, but I just wanted make sure I read you correctly ...
This means we'll have to installed the additional sensors for 'EGT x 2, IAT, TPS, Oil Temp, Coolant/Water Temp, Oil Pressure, Fuel Pressure, Boost, RPM, Speed, etc, etc.' ???
Old Jan 18, 2004 | 05:36 PM
azrael's Avatar
azrael
yup. pain in the ***, but it makes the install very general (works across brands/models) and also eliminates the possibility of loading down the stock sensor
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
