Ingalls 350z engine damper >>Help needed
Old Jan 11, 2013 | 05:29 PM
mike_eee's Avatar
mike_eee
Question Ingalls 350z engine damper >>Help needed
Guys with Ingalls 350z engine damper installed in their DE or rev-up engine can help me please.
well to be short..i tried to use the stillen damper and i damaged the screw hole on the timing cover and hence I would like to avoid this hole and use any other mounting hole on the engine block for a different damper and I came across ingalls..from instructions its not clear if it uses the same hole on the timing cover or different ..so ownes, could u please snap a pic of ur install esp showing which mounting holes have been used on the engine TC cover for the install. your help will be really appreciated.
mike
Old Jan 13, 2013 | 03:03 AM
MR RIZK's Avatar
MR RIZK
Why dont you fix the hole with a recoil kit?
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
codek
Sep 27, 2015 03:21 PM
