Torq seting for the throttle body
Old Jan 16, 2004 | 03:53 PM
az240z's Avatar
az240z
Default Torq seting for the throttle body
I am replacing my plenum with a used Crawford Plenum. I stripped my stock one down, taking of the throttle body, when I tried to tork the bolts down on the throttle body the heads started to strip. According to the repair cd that I have it calls for setting of 64-85 ft lbs. Is this correct? The settings for all the outer edge bolts shows 56-73 ft. lbs. Are these the correct settings?
Also I had some trouble getting the 3 top bolts to line up. Has anyone else had this problem installing a used plenum?
Thanks for your help.
Az240z
Old Jan 16, 2004 | 04:01 PM
350zdanny's Avatar
350zdanny
That's the right torque setting. I've never had trouble lining the bolts up though, or a problem with them stripping.
Old Jan 16, 2004 | 06:13 PM
DaveO's Avatar
DaveO
Default Re: Torq seting for the throttle body
Az240z
Remember you're working with aluminum.
The shop manual indicates the torque for the collector (plenum) bolts is 9-10 ft-lbs (108-120 in-lbs) and 64 to 85 IN-LBS (5.3 to 7 ft-lbs) for the throttle body.
DaveO
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
