NISMO 46cc Heads inspected... to be installed \m/, ^_^ .\m/
Old Jan 17, 2004 | 07:55 AM
DaveO's Avatar
DaveO
Default Re: NISMO 46cc Heads inspected... to be installed \m/, ^_^ .\m/
Jason,
Will the valves be the same size? It's hard to tell by the pictures.
DaveO
Old Jan 17, 2004 | 08:29 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Jason is more optimistic than I am!! I'm hoping for about 275+ on the dyno. SOME of the other mods we'll do at the same time include.... Nismo oil cooler, Nismo T-Stat, JIC Y-Pipe, JWT Pop Charger, AEM wide band A/F gauge, and dyno tuning by T/S. This is about as far as we can go with bolt on parts (other than a plenum) and we want to see what happens. After this project is up and running for a month we will start the new Forged motor for my car and throw on the Turbo kit as well. DAMN, I LIKE WORKING HERE!!!!
Old Jan 17, 2004 | 08:49 AM
Ultimateone's Avatar
Ultimateone
Good lord...your car will be a beast!
Old Jan 20, 2004 | 05:41 AM
g356gear's Avatar
g356gear
Originally posted by Nathan
Jason
When you get round to CC,ing the unswept area & do your calculations you will find these heads on the stock motor will be about 12.3 to 1 CR.
Also that 2mm you mention is what I was saying about the available cam followers not being in range for lash adjustment with the stock, Tomei , Nismo or any cam with the stock base circle.
Thats why Nismo has made available cam blanks so that the Engine builder can take advantage of the extra lift that these RZZ heads can accomadate
Enthusiasm and haste can breed disaster.... knowledge and experience are golden.
Old Jan 20, 2004 | 06:06 AM
Jeff@Performance
Performance Nissan
This is why we test the products on my car first. It will give us a much better understanding of what happens if.......
Old Jan 20, 2004 | 06:12 AM
g356gear's Avatar
g356gear
I think Nathan already has posted the problems you will encounter with these heads.....from his own experience of course. But I guess some people have to try for themselves.
Damn those Aussies.
Old Jan 20, 2004 | 08:35 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
but those were not THESE heads... different part numbers can mean a huge difference...
Old Jan 20, 2004 | 10:02 AM
g356gear's Avatar
g356gear
Then I am curious how many variations of the RZZ head Nismo lists.
Old Jan 20, 2004 | 10:26 AM
Jason@Performance
Performance Nissan
so far we have 2... left side and rite side... all thats availble for heads from nismo...
Old Jan 20, 2004 | 12:59 PM
Nathan's Avatar
Nathan
They are THESE heads.
The part # I mentioned ( 11091- RRZ30-1) was a # that was texta,d on the box the left hand head came in.
I have had these heads ( RRZ 46cc ) since June 19 2003 but was unable to mention them as they were supplied to us on a confidential basis for racing use.
We race in a Production based series here in Australia & our sanctioning body have not yet cleared these heads for use.
We are in the process of getting the blank cams ground to suit the new heads & with new pistons, applying to use the combination in this years championship.
Old Jan 20, 2004 | 02:02 PM
Jeff@Performance
Performance Nissan
I kind of missed where this was going.... So my car is in the shop out back and the heads are almost off. Are you saying my Nismo Cams won't go into those heads? HUM... this can't be good...
Old Jan 20, 2004 | 02:05 PM
FLY BY Z's Avatar
FLY BY Z
Yeah he said that on the first page.
Old Jan 20, 2004 | 02:44 PM
Jeff@Performance
Performance Nissan
ya' guess I should have read Jason's whole thread. Missed that. Well, guess we'll confirm or prove it wrong on Wednesday..... I'm not feeling too good about this anymore. On the bright side, if that's the case then I'll pull the motor out and work on the forged bottom end instead...
Old Jan 20, 2004 | 02:55 PM
FLY BY Z's Avatar
FLY BY Z
hey since the tomeis have to be shimmed and adjusted to fit the stock head maybe they will fit this head without adjustment. call sgpracing and see if kyle knows.
Old Jan 20, 2004 | 03:51 PM
RedShft's Avatar
RedShft
will you still be able to run 93 octane with these heads? i think a PnP job would be a better money value personally.
Old Jan 20, 2004 | 04:03 PM
Nathan's Avatar
Nathan
Jeff will soon be able to confirm or refute what I have been saying about these heads.
But hears a little Math
Swept area + unswept area divided by unswept area = CR
Swept area: 3498cc devided 6 (cyls) = 583cc
Head CC 46cc + Head gasket area, aprox 5cc : total unswept area 51cc
583 + 51 = 634cc devided by 51 = 12.43 CR
Old Jan 20, 2004 | 04:14 PM
Jeff@Performance
Performance Nissan
Cool, we can deal with that.. Now if only the cams go in.. Even our race team manager is watching to see what happens. He's whining because he has to run stock cams and heads and is in the process of getting that changed as well with the racing officials.
Old Jan 20, 2004 | 04:18 PM
  #38
daytona350z's Avatar
daytona350z
hey jeff...just wondering....if u use these heads, will your stock ones be for sale? or are you gonna use them on a different engine?
thanks
Old Jan 20, 2004 | 04:20 PM
  #39
FLY BY Z's Avatar
FLY BY Z
you can run 93 with these but you will have to compromise some timing just like FI guys are having to do. also, you may be right that a P&P job will be better value especially if you have to custom grind cams to fit these heads!
This head may just be a high performance version of a stock piece intended just for the racers (as mentioned) like a Chevy "Bowtie" block that is thicker and can handle more power. These parts exist and it sort of sucks that they aren't compatible with other stock pieces. However, we shall see as soon as Jeff fits them.
Old Jan 20, 2004 | 04:27 PM
  #40
jesseenglish's Avatar
jesseenglish
The deck height is 0 on this engine?
