Replaced Belts, Quick Squeal on Cold Start
Old Jan 27, 2013 | 04:35 PM
johnnyvq's Avatar
johnnyvq
Default Replaced Belts, Quick Squeal on Cold Start
I recently had my two belts replaced and now on cold starts there is a quick squeal. Only lasts for a second then it goes away.
Anyone have an opinion on the cause?
Old Jan 27, 2013 | 04:59 PM
Jennifer 2's Avatar
Jennifer 2
A new belt will settle in to the pulley groves and wear in a bit causing some loss of tension. A momentary squeal on a cold start up is a sure confirmation of a loose belt. On a 350Z it’s always the larger alternator belt that squeals. Take it back for an adjustment, or better yet do it yourself.
There are some great DIY write-ups on tensioning the belts on this site. The spec for how tight to make the larger belt is a 4 to 5 mm deflection with a 22 lb pressure mid span between the pulleys.
When I helped my friend tension my car’s belt, I was the 22 lb pusher. What I did was push down on a bathroom scale to calibrate my thumb, and then applied the same push to the belt.
Old Jan 27, 2013 | 05:03 PM
r_seng's Avatar
r_seng
^ Couldn't have said it better myself. ^
Old Jan 27, 2013 | 05:09 PM
johnnyvq's Avatar
johnnyvq
Thanks! I'm going to take it back to the dealership tomorrow so they can fix their mistake. What else is new.
Old Jan 29, 2013 | 10:06 AM
J.$'s Avatar
J.$
You go girl!
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
