ECU and 4 smoked plugs
Old Jan 19, 2004 | 03:24 PM
KJY9's Avatar
KJY9
Default ECU and 4 smoked plugs
Had my ECU flashed in Dallas last Thursday.
Attached are the Dynos showing A/F ratios.
4 smoked plugs later and it's back to the newest stock flash from the dealer.
Anyone see anything that pops off the page at you around 2275 RPMs?!?
Old Jan 19, 2004 | 04:11 PM
MY350Z.COM's Avatar
ewwwww
Old Jan 19, 2004 | 04:16 PM
jesseenglish's Avatar
jesseenglish
Ummmmm yeah..... Looks like your ECU reprogrammer needs to go back to the drawing board.
Old Jan 19, 2004 | 04:43 PM
ajk4's Avatar
ajk4
who tuned your ecu??
Old Jan 19, 2004 | 06:11 PM
Chebosto's Avatar
Chebosto
is this the Fisher ECU? yikes..
MY350Z.COM's Avatar
I'm pretty sure Fisherspeed in Dallas did it. They've been trying to get it out lately.
Old Jan 19, 2004 | 06:19 PM
KJY9's Avatar
KJY9
AFAIK there are only two shops doing flashes, one on the west coast and one in Dallas.
You guys can figure it out. This post wasn't to slam the person that did it. It was more of a "be wary of who you let flash your car" and make sure they know what they're doing
Old Jan 19, 2004 | 06:32 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Hello, my name is Jason, I run RT Cats and I am burning RICH. Is there something wrong with me?
Old Jan 19, 2004 | 06:34 PM
KJY9's Avatar
KJY9
Old Jan 19, 2004 | 06:45 PM
Chebosto's Avatar
Chebosto
KJY9-
did they alter all three maps?
Old Jan 19, 2004 | 06:54 PM
KJY9's Avatar
KJY9
Originally posted by Chebosto
KJY9-
Timings (*added in at certain points, then took some out*)
A/F (*not sure if there is more than one map for this or not, but if there are, then both were obviously manipulated*)
Throttle Body
Rev Limiter
Top Speed governor
Old Jan 19, 2004 | 08:13 PM
KJY9's Avatar
KJY9
Another question....as I have no idea here whatsoever...why the obvious downspikes in gear ratio after the flash??
Old Jan 19, 2004 | 08:54 PM
Ethan's Avatar
Ethan
It is from the RPM pickup not maintaining a clear signal throughout the run.
Regards,
Ethan
Old Jan 19, 2004 | 09:09 PM
chazzg's Avatar
chazzg
So you went back to the Stock Flash? What went wrong? PM or Email me with all the Info if you do not want to post it here.Did you have your Dealer do the stock reflash or did you do it down here?
Old Jan 19, 2004 | 09:34 PM
KJY9's Avatar
KJY9
PM sent
Old Jan 20, 2004 | 03:03 AM
mjedens's Avatar
mjedens
Default KJY9 ?
Chazzg asked a good question! Can a Nissan Dealer put our ECU's back to "stock condition"! I have a similiar spike in A/F at about the same rpm range as above. If you take out the "smoothing" on your dyno run sheet it will look even scarier!
Old Jan 20, 2004 | 05:37 AM
KJY9's Avatar
KJY9
Default Re: KJY9 ?
Yes they can...and did mine!
Old Jan 20, 2004 | 05:48 AM
FairladyZ's Avatar
FairladyZ
Did you contact the guy that did the tuning? What did he say?
Old Jan 20, 2004 | 05:50 AM
FairladyZ's Avatar
FairladyZ
Also did you check your plugs b4 the tune? Looks okay to me. You have alot of exhuast mods, so you could have been running rich the whole time. With the tune he could have fixed your problem.
Old Jan 20, 2004 | 05:52 AM
PhoenixINX's Avatar
PhoenixINX
Wow... That sucks Kevin, sorry to hear about your mis-hap...
What are they doing to compensate you for all this?
They paying to get it flashed back to stock, labor, and plugs I'd hope??? Zero excuse for letting it lean out that badly down low.
