automatic with rev up swap?
Old Mar 20, 2013 | 11:37 AM
silva92's Avatar
silva92
Default automatic with rev up swap?
Hey guys I have a 03 auto Thst my motor is beyond repair. . I cane across this Rev up motor. I jumped on it. . Basicly I'm getting mixed answers.
If I use my harness and ecu leave the cam sensors unplugged. Will it run and line up
Old Mar 20, 2013 | 01:26 PM
silva92's Avatar
silva92
I guess what im asking is. Will my automaric trans bolt up to this rev up motor and will it run without the correct ecu and harness
Old Mar 20, 2013 | 08:59 PM
tpinto0260's Avatar
tpinto0260
Your going to need that ECU and Harness.
Old Mar 20, 2013 | 09:47 PM
terrasmak's Avatar
Easier to install the rear cam plugs , swap cams and front timing covers from your DE and install it as a DE. No wiring will be needed. Very easy to convert from a rev up to a normal DE
Old Mar 21, 2013 | 03:55 AM
silva92's Avatar
silva92
If I left the cams in it wouldn't perform correctly? I knew I had to cover the cam sensors..
Im just not ready to play with the timing on this motor.
I dont mind having those front covers exposing un plugged sensors
Or the lack of variable exhaust cam
Old Apr 4, 2013 | 03:03 AM
silva92's Avatar
silva92
Cars runs like a regular de if u leave front sensors unplugged and the extra exhaust cam sensors u plugged. As expected I dont have variable exhaust timing but it still performs great with no idiot lights on.
Old Apr 5, 2013 | 06:48 AM
tpinto0260's Avatar
tpinto0260
Right on, I think it would be a great idea for you to create a detailed writ-up on the process and post it in the DIY section of this forum.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
SharX59
Sep 27, 2015 09:23 AM
