Flooring has pedal as you shut the engine off
Old Mar 21, 2013 | 02:31 PM
Sean3909's Avatar
Sean3909
Default Flooring has pedal as you shut the engine off
How bad is it for your car to rev it up to say 1500-2000rpms and then at the same time, slam the gas pedal and turn off the ignition? If I do this the engine very roughly slows down until it stops with a very violent shake and it sounds like a diesel firing a couple times. I've been told I could flood the cylinders but wouldn't the ignition cut off the fuel injection? Somehow the throttles are still opening because it sounds way different and you can hear more air going through there. Wouldn't cutting the fuel as you rev it and open the throttles up blow leftover fuel out? How bad is it for your car? Could I maybe mess up the bearings or something stopping that way? 2008 350z
Old Mar 21, 2013 | 02:41 PM
j3tt2's Avatar
j3tt2
Why would you even do this?
Old Mar 21, 2013 | 03:10 PM
bmyles's Avatar
bmyles
I hope this is a troll...
Old Mar 21, 2013 | 03:15 PM
j3tt2's Avatar
j3tt2
He put the year and 350z like we didn't know he drove a 350z or that it mattered it was an 08 that he's being a tard dick
Old Mar 21, 2013 | 03:17 PM
04.350z's Avatar
04.350z
If you are looking for a real answer ill give you one....
Old Mar 21, 2013 | 03:19 PM
andre12031948's Avatar
andre12031948
"the engine very roughly slows down until it stops with a very violent shake"
Is this thread for real??? ^^^^^ does that sound like it's good for the engine? No wonder this country has a low education ratings.
Coming from a H.S. drop out
Old Mar 21, 2013 | 03:49 PM
DaveJackson's Avatar
DaveJackson
Master
Yeah. Every time I throw a handful of sand in the intake after going to a lot of needless inconvenience, the engine makes a crazy noise, too. Could these things be related?
Old Mar 21, 2013 | 04:05 PM
Sean3909's Avatar
Sean3909
Pretty sure the engine can take some ****. It would probably even be ok if you ran it with knock for a good while. I just wanted to know what specifically i could be messing up if I kept doing it. Still works and hauls *** so I'm happy
Old Mar 21, 2013 | 04:09 PM
j3tt2's Avatar
j3tt2
Yeah..... Because racecar......
This can't be real? So your happy with a busted *** engine?
Old Mar 21, 2013 | 04:17 PM
Sean3909's Avatar
Sean3909
Well I've only done it once so if that messed it up I'd be pretty surprised. I had an rx8 with a rotary motor that if you shut down the engine early while it was still cold it would usually flood. I've heard u could avoid this by doing what I said. Prolly doesn't do anything beneficial like that in the z because its piston. Definitely a lot rougher and makes different noise. I don't plan on doing it habitually.
Old Mar 21, 2013 | 04:21 PM
j3tt2's Avatar
j3tt2
Cool an rx8...... With a rotary motor....... Did they have any other motor in those?
Old Mar 21, 2013 | 04:22 PM
andre12031948
^^^^^^^^^^^ That's great. "Hauls *** so I'm happy". That's all that counts. Don't worry about the knoking. You hear it less at higher rpm.
Old Mar 21, 2013 | 04:30 PM
Sean3909's Avatar
Sean3909
Ok so it'll completely blow it up..? Even 1 time
Old Mar 21, 2013 | 05:08 PM
saywat?'s Avatar
saywat?
^nah keep doing it . makes the motor stronger
Old Mar 21, 2013 | 08:35 PM
TuckerE36's Avatar
TuckerE36
I remember for the Rotary engines it was good to bring the engine just below 2k rpms and then cut it off. That's for a rotary engine though, don't know why you'd think the same concept applied for a piston engine.
Old Mar 21, 2013 | 08:53 PM
Waiz's Avatar
Waiz
What would be the purpose of this is more the question?
Old Mar 22, 2013 | 06:52 AM
QTB's Avatar
QTB
I shouldn't participate in this ....
I think what our friend is referring to is dumping fuel into the combustion chamber prior to turning off the engine. I think this was some sort of myth that was from the good 'ole day of carburetors to help create a richer AFR under cranking the next time you start the engine. What it really does is wash down your cylinder walls with fuel, robbing them of any residual oil prematurely wearing out your rings. It also then continues to wash down the walls and seeps past the rings, into your oil sump. This then dilutes your oil causing other issues with all those pesky bearings in your engine.
As I continue to ramble on…. I can’t speak to wankle engines but you don’t need to do this, not then, not now. EFI has cleared up most cold start issues provided nothing is broke.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
