Engine build problems!
Old May 21, 2013 | 10:50 AM
velodyne's Avatar
velodyne
Default Engine build problems!
Was wondering if anyone has any input on this. I had my '03 motor rebuilt due to bad rings at a performance shop. I put Arias 9:0 pistons with eagle rods and arp bolts, cometic gasket etc... after 1000miles the motor was badly smoking so they opened it up to find the cylinder walls egg shaped. Thinking it was the machine shop they brought it to a different one. Once again after about 1000miles its back to smoking again!! They think its a bad block (soft walls or something) or could it be the pistons (they have a very short skirt on them).
Old May 21, 2013 | 11:53 AM
350z006's Avatar
350z006
Wow...did the cylinders egg up before the engine break in?
Old May 21, 2013 | 05:58 PM
binder's Avatar
binder
If the pistons are still square then it's a bad bore job.
I've never heard of the walls being "too soft".
Old May 22, 2013 | 08:03 AM
velodyne's Avatar
velodyne
Ya same here I've never heard of walls being soft. I'm leaning towards the pistons. But I know either way he's using a different block so I think I should swap the pistons too although they're pretty much brand new
Old May 22, 2013 | 09:22 AM
jerryd87's Avatar
jerryd87
sounds to me like someone simply dosnt know what they are doing, your going to have something really messed up to cause that, the stock cylinders are thick as ****.
Old May 22, 2013 | 10:46 AM
binder's Avatar
binder
They can easily check the pistons for out of round. I would have them checked fully before using them again.
Uriyo_
Sep 8, 2021 08:46 AM
