Tuning new injectors
Old May 24, 2013 | 10:04 AM
Zjul8r's Avatar
Zjul8r
Default Tuning new injectors
Need help. I am upgrading my 380cc injectors to 600cc DW injectors and Walbro fuel pump. My question is after I make the swap can I drive it gently to a tuner without changing maps? I dont have a cable.
Old May 25, 2013 | 02:25 PM
evilscorp's Avatar
evilscorp
You will struggle, I tried to drive mine around for a few days with 600cc DW walbro and a fuel return (with a vortech v3 also). It ran pig rich and bogged down a lot even with me reducing the fuel pressure. Ended up having to hire a trailer as I didn't want to damage the engine.
Old May 26, 2013 | 07:03 AM
Zjul8r's Avatar
Zjul8r
I wanted to do the injectors myself but now i think ill have the tuner do them. Thanks for saving me a hassel!
Old May 26, 2013 | 07:25 AM
04.350z's Avatar
04.350z
Drive z to tuner bring tools with change injectors in parking lot hand car to tuner
Old May 26, 2013 | 09:10 AM
Zjul8r's Avatar
Zjul8r
Great Idea! Thanx
Old May 26, 2013 | 12:06 PM
evilscorp's Avatar
evilscorp
No problem, I had a 240 mile trip to my tuner, it would have been fine if the road was flat but any hills/load on the engine and it really struggled, so much so I thought the car was going to come to a stop once
Old May 27, 2013 | 05:31 AM
04.350z's Avatar
04.350z
That's what I would do ... bring a 10 12 and 14 mm a 3/8 ratchet ans if you really wanna move fast an electric impact.tuner may not like it but in that case do it a few blocks down
Old May 27, 2013 | 12:49 PM
Zjul8r's Avatar
Zjul8r
I just had the plenum and intake off and on with new gaskets, do you think i will need new gasket kit?
Old May 27, 2013 | 05:01 PM
binder's Avatar
binder
In vacuum you have 20% o2 correction so if you are light in the throttle then it should be fine.
Do you have a return fuel system with an adjustable fuel pressure regulator? You can drop the fuel pressure which would make those 600's act like smaller injectors for the drive.
Old May 28, 2013 | 07:37 PM
Zjul8r's Avatar
Zjul8r
No, single line feed. But good thought
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
