350z rear end/ differential failing
Old Jun 6, 2013 | 08:04 AM
dmill's Avatar
dmill
Originally Posted by Emski
Name calling? You must be young.
No Barbie car here. Read my sig. Having fun is cool. What we are trying to say is keep it at the track. It's the thing you've probably never set foot on.
Drag strip, but not road racing
Old Jun 6, 2013 | 08:12 AM
bmyles's Avatar
bmyles
Originally Posted by dcains
VLSD is a viscous coupling between the two output shafts - no spider gears, no clutches. There is a pinion gear attached to the driveshaft, meshed to the ring gear, onto which the sealed VLSD housing is bolted. One output shaft attaches to each end of the VLSD housing.
As for the OP, an old Bhuddist teaching suggests we "contemplate the vase already broken".
Look in the FSM, RFD-14. It has what are called Side Gears, Pinion Mate Shaft, and Pinion Mate Shaft Gears inside. So you technically can break a gear inside, but it would be a big fluke and about 99.9% chance it's a factory defect.
Old Jun 6, 2013 | 08:14 AM
dmill's Avatar
dmill
Originally Posted by jerryd87
you have alot to learn other dude is plain wrong that there is no spider gears it couldnt work without them but your also plain wrong on there having to be clutchs not even close to the case even with the lsd. on to your issue the problem is you, your obviously doing something that shouldnt be done or doing something wrong because there are people here who make 600+ on stock rears with absolutely no issues. my bet is low or no fluid in them
Ok maybe theyre called something different, im just talking about the parts that allow both wheels to spin at different speeds. And i had the new pumpkin put on last year with a rear end oil change. So unless, it leaked, theres has to be another issue. Maybe it was just a bad part. Ill get another vlsd and try that i guess.
Old Jun 6, 2013 | 08:18 AM
dmill's Avatar
dmill
Thats kind of what i was thinking. I notice my car bounces a lot when trying to get traction on a hard take off. When i got the vlsd, i figured itd resolve the problem. Anyone else notice this about their cars?
Old Jun 6, 2013 | 08:28 AM
NissanZguy's Avatar
NissanZguy
You bought a ebay vlsd and you wonder why it broke?
Your car broke because your a stupid ricer, thread/
p.s. Get off the street and take it to the track moron.
Old Jun 6, 2013 | 08:55 AM
QTB's Avatar
QTB
Is your car bouncing or are you getting wheel hop? If you're getting wheel hop then solid diff mounts will fix you up. If your clutch is working then you either broke something in the diff or an axel, but I'm pretty sure if your axel was broke you'd know it, Drop the diff cover and see what's laying in the bottom. If you're getting excessive wheel hop and you're 'staying in it' you can break all sorts of stuff. Then remove VLSD crap and replace with something good and fix what the pieces in the bottom of the diff are from. I'm a current user, and a fan of the NISMO GT LSD, but everyone has there own favorite.
Old Jun 6, 2013 | 08:58 AM
Jbakes727's Avatar
Jbakes727
I'm not defending dmill but common guys don't act like you've never done a burn out on a public road in your Z at least once...
Old Jun 6, 2013 | 01:06 PM
HK350 Z's Avatar
HK350 Z
I have NEVER attempted or performed a burnout in 2+ years of owning my Z, and dont plan on it...
Old Jun 6, 2013 | 01:17 PM
stuartc323's Avatar
stuartc323
no cuz i dont drive like an asshat on surface streets, I save that for the track where my Z can actually perform.
OP, your car broke itself because it realized your a dumbass. We can correct that though, The VLSD is garbage compared to an aftermarket unit, such as Quaife or OS Giken, the problems your having can be fixed by installing one of these, the solid diff mounts would only be a quick fix.
Old Jun 6, 2013 | 01:27 PM
NissanZguy's Avatar
NissanZguy
It's pretty juvenile.
Old Jun 6, 2013 | 05:09 PM
Emski's Avatar
Emski
It's the wheel hop from the burnouts. When a car gets older the bushings wear out. The abrupt force from dropping the clutch pushes the wheels out of alignment, and thus the rapid slip and grip is the "bounce" you are experiencing (someone correct me if I am wrong). I think someone already mentioned that diff bushings help. Usually when people drag their car the axles snap first. Breaking the diff means you are doing something wrong.
Old Jun 6, 2013 | 06:55 PM
jerryd87's Avatar
jerryd87
wrong, tried to find a pic to show you but all the pics are of sealed diff's online, so go look at the service manual, there is still spider gears in the diff, heck even clutch type use it, the only thing that dosnt is helical gear type lsd's(and even they sort of do just not in a traditional configuration) or spools. its impossible to bias torque or allow different speeds from the axles without some sort of spider gear device.
edit: this isnt a 350z diff but our viscous and every single other viscous diff on the planet works like this though. its why the viscous unit uses a longer axle shaft on one side.
Old Jun 6, 2013 | 06:57 PM
dmill's Avatar
dmill
I mean, it was off a totaled 350z. So get your facts straight ****in dipshit.
Old Jun 6, 2013 | 07:16 PM
dmill's Avatar
dmill
Ok, thanks. Ill look into the solid diff mounts and take it easy for a while. Thanks for the info. Much appreciated.
Old Jun 6, 2013 | 07:26 PM
dmill's Avatar
dmill
Thats what im saying. I was blind to this but i think everyone dissing me on the whole burnout deal must be like 50 or something and know better. Haha, im just 19 guys and im invincible . If anybody else wants a reason to mouth me, i also did 155mph on a public highway . Now if we can stop talking about me being "dumb" cause I know I do stupid ****, id appreciate it. Im young and like to drive hard. So do all my buddies. Im sure you guys did dumb stuff when you were teenagers as well. My dad also taught me to drift, blame him. He races though. Haha. So now, lets talk about useful info and safety features i can get to keep this from happening again. Thanks!
Old Jun 6, 2013 | 07:32 PM
dmill's Avatar
dmill
Alright, thanks for actually helping me find the answer to my original question to why did it fail. Thats all i was wanting to know...
Old Jun 6, 2013 | 08:04 PM
jerryd87's Avatar
jerryd87
you would be suprised at how many mid 20 to mid 30 year olds are here and this post pretty much just guaranteed for you to be ignored for the typical 19 year old know it all better then everybody attitude, snap outa it quick it just pisses people off and gets you no where. being that your 19 chances are very good your a **** driver since 99% of 19 year olds are and it broke from abuse.
Old Jun 6, 2013 | 10:10 PM
  #38
dmill's Avatar
dmill
Theres a difference between being a **** driver and occasionally driving like a bat out of hell, that i do on country highways where you cant see cars for miles. And my additude was sarcasm. And i dont know it all. Not even close, thats why i asked about this failing and what i could do to fix the problem. But immature people had to run theyre smart *** mouths about me doing a burn out. Like who cares? I did it, it broke, its done. All I want is a simple ****ing answer that i didnt get until 30 replies later after everyones ignorant comments blew up the thread. Im a Purdue aerospace Engineering student... Dont really need people tell me im a "dumbass" when half of them dont know what theyre talking about.
Old Jun 7, 2013 | 07:38 AM
  #39
stuartc323's Avatar
stuartc323
But you cant figure out a simple VLSD problem? LOLz
And JerryD is right, your an asshat, and I really dont think that was sarcasm, how about you get a job, get off public roads, and go with your dad to the racetrack and race there. Thats all we are saying. If you dont like our approach, buy a damn Prius, otherwise dont get butthurt when you tell people about the dumbshit that you do, and then get flamed for it, I swear kids these days cry over a ****ing paper cut.
Old Jun 7, 2013 | 08:33 AM
  #40
NissanZguy's Avatar
NissanZguy
You bought a part off a broken Z, on ebay, and Im the dipshit?...wow
He's 19, he's 2 kool fo common sense yo!
