350z rear end/ differential failing
Old Jun 5, 2013 | 02:04 PM
dmill's Avatar
dmill
Default 350z rear end/ differential failing
Can anybody help me out here?
My stock rear end with open differential failed on me last summer. I bought a used one off ebay with VLSD. Last week i was doing a burn out and this one failed too!!!!! Wtf! Im really getting pissed off with the rear ends not holding up. Are the Nissan rear ends really that big of peices of ****??? Has anybody else had this problem? Please leave input. Im very frustrated and want a solution without spending $1100 on a Quaife LSD. Whats going to hold up? My cars pretty much stock besides a stage 2 clutch, intakes, and 295 wide tires in the back.
Old Jun 5, 2013 | 04:29 PM
bigbirdmodeZ's Avatar
bigbirdmodeZ
your post is about to get moved. Youll have better luck posting in the appropriate section.
Old Jun 5, 2013 | 05:17 PM
Emski's Avatar
Emski
Why were you doing a burnout?
Old Jun 5, 2013 | 06:20 PM
terrasmak's Avatar
What failed, bearings , gears , spider gears?
Old Jun 5, 2013 | 06:25 PM
dcains's Avatar
dcains
Why else? Sold the Civic, bought a Z, having fun? Really, time to grow up.
Old Jun 5, 2013 | 06:49 PM
Bmurray350z's Avatar
Bmurray350z
yeah you need to elaborate on the "failed" part
Old Jun 5, 2013 | 06:50 PM
dmill's Avatar
dmill
My guy hasnt opened it up yet. But were sure its either the spyder gears or the clutches inside the diff.
Old Jun 5, 2013 | 06:53 PM
dmill's Avatar
dmill
It was just a loud pop from the rear end when i dropped the clutch, then the car wouldnt move afterwards. It would move slightly but it acted as major clutch slippage. The shop confirmed that it wasnt the clutch though.
Old Jun 5, 2013 | 06:59 PM
dmill's Avatar
dmill
Idk, Your telling me you dont? Its a Z! Just some spirited driving. Ill admit, i drive the roads occasionally like its a race track, drifting corners, wrapping through the gears. I mean, thats what its made for. I cant wrap my head around how this could fail on me, then fail again after an upgrade to LSD.
Old Jun 5, 2013 | 07:12 PM
Bmurray350z
it failed because you drift on public roads like a moron and jesus zapped you
/thread
Old Jun 5, 2013 | 07:41 PM
dmill's Avatar
dmill
/thread
Looking for actual reasons, not ignorant comments. And I actually drive out of town on back roads. Where me and my buddies drift and drag race. So anyone else wanna help out.
Old Jun 5, 2013 | 08:29 PM
dcains's Avatar
dcains
There are no spider gears or clutches inside that diff. You're an idiot, and that's reflected in your driving and repeated abuse of your car. What exactly did you expect anyone here to tell you?
Old Jun 5, 2013 | 08:43 PM
terrasmak's Avatar
How much power do you have? Never really heard of a Z breaking a diff unless on full slicks with added power. I beat the hell out of my car, had 120k on my first diff (upgraded to OS Giken) and 35k on the OS unit. Only prob so far is a fried pinion bearing, found it when I swapped to 3.7 gears.
I really think you are fking up some how.
Old Jun 5, 2013 | 08:50 PM
Emski's Avatar
Emski
No I don't do burnouts because I don't drag with race tires. You are so full of yourself but you are correct about one thing. Time for you to grow up.
Old Jun 5, 2013 | 09:01 PM
dmill's Avatar
dmill
Full of myself? Didnt know that having fun driving a car was being full of myself and immature. You must be one of those pussies that drives 5 under and has an automatic.
Old Jun 5, 2013 | 09:19 PM
dmill's Avatar
dmill
Ok, didnt know the stock diffs were made without spyder gears. And theres has to be clutches to allow it to distribute power. Since youre an expert, i guess you can tell me what kind of diff i should run, how to keep it from breaking again, have u or anyone else had this problem?? Enlighten me
Old Jun 5, 2013 | 09:32 PM
dmill's Avatar
dmill
Yeah, I dont get it. The cars pretty much stock. I have a clutch thats like an on/off switch. It might just be grabbing so hard, when i drop it, it puts too much on the rear end...
Whats youre take?
Old Jun 5, 2013 | 10:11 PM
Emski's Avatar
Emski
Name calling? You must be young.
No Barbie car here. Read my sig. Having fun is cool. What we are trying to say is keep it at the track. It's the thing you've probably never set foot on.
Old Jun 5, 2013 | 11:58 PM
jerryd87's Avatar
jerryd87
you have alot to learn other dude is plain wrong that there is no spider gears it couldnt work without them but your also plain wrong on there having to be clutchs not even close to the case even with the lsd. on to your issue the problem is you, your obviously doing something that shouldnt be done or doing something wrong because there are people here who make 600+ on stock rears with absolutely no issues. my bet is low or no fluid in them
Old Jun 6, 2013 | 12:14 AM
dcains's Avatar
dcains
VLSD is a viscous coupling between the two output shafts - no spider gears, no clutches. There is a pinion gear attached to the driveshaft, meshed to the ring gear, onto which the sealed VLSD housing is bolted. One output shaft attaches to each end of the VLSD housing.
As for the OP, an old Bhuddist teaching suggests we "contemplate the vase already broken".
