Manual tranmission questions.
Old Jul 8, 2013 | 02:04 PM
l2frankie's Avatar
l2frankie
Default Manual tranmission questions.
i have a few questions regarding manual transmission.
1st question is when driving manual is it bad in any way to drive without pressing the clutch inbetween the gears?
2nd i heard its bad to redline the car when in nuetral vs when in motion.
I had a 3rd question but i seem to have forgotten it lol
Old Jul 8, 2013 | 02:23 PM
dcains's Avatar
dcains
1) You can shift gears quite nicely without disengaging the clutch - if you match the revs exactly. If not, you'll cause lots of extra, premature wear on the syncro's.
2) Why would you even want to do such a thing?
Old Jul 8, 2013 | 02:29 PM
flynzed's Avatar
flynzed
1. If the engine rpms don't match the gear rotation speed in your transmission you will grind the gears witch is never good.
2. Whenever you rev an engine out of gear there is no resistance allowing engine components to slap around, again not a good thing. Can you do it, sure, however the faster and longer you free rev an engine you increase the chance of damange.
Old Jul 8, 2013 | 04:44 PM
l2frankie's Avatar
l2frankie
i knew about the whole gear grinding was just curious if it did any other kinda of damage it may cause. i dont redlin my car in nuetral it was just something i heard. i remembered my 3rd question when downshifting gears 6-2 go in smooth. going down to 1st gear i literally need 2 put some force when trying to push it in gears dont grind just hard to go in. it this normal for a 350?
Old Jul 8, 2013 | 05:15 PM
oldschool350z's Avatar
oldschool350z
For any car with a manual transmission its a saftey feature to not be able to down shift to first. Easy way to blow the engine i.e. trying to shift to third and get first at 60 mph.
Old Jul 8, 2013 | 05:23 PM
l2frankie's Avatar
l2frankie
i see. so should i not down shift into 1st? i down shift to 1st gear around 2000 or less rpms if that helps any. Thanks for the help guys
Old Jul 8, 2013 | 08:13 PM
HK350 Z's Avatar
HK350 Z
Most Nissan manual transmissions lock out first gear after 5 mph+...
Old Jul 8, 2013 | 10:03 PM
dcains's Avatar
dcains
No, they don't. It's just that there is a larger difference in gear ratios as you shift down in each gear from 6th to 1st, so the difference in engine revs between gears is also larger. I have a long private driveway to my house, which is very bumpy, and I shift down into 1st on a daily basis. If the engine revs are matched properly, the shift lever slides into 1st just as easily as in any other gear during a downshift. I will say, though, that in most circumstances downshifting into 1st is fairly useless.
Old Jul 9, 2013 | 04:21 AM
djamps's Avatar
djamps
Don't put it in 1st until you're stopped or going very slowly. If I'm not completely stopped I'll usually just start in 2nd (bogs a little but that's one less shift). Lately I've been getting lazy, doing 1-3-5 or 1-2-4-6.
Old Jul 9, 2013 | 06:22 AM
l2frankie's Avatar
l2frankie
when i downshift into 1st ill be going maybe 10 mph? but either way no matter what my revs are its still stiff to go in. aslong as i know its not doing any harm to my baby then im happy
Old Jul 9, 2013 | 07:18 AM
HK350 Z's Avatar
HK350 Z
If you say so chief , because most car companies like people shoving the car into first gear accidently while at high speeds , does great things for the transmission.
Didnt say you couldnt get around it, but the lock out is there.
Old Jul 9, 2013 | 01:48 PM
SQuaLZ's Avatar
SQuaLZ
It is hard to get back into 1st but it is still possible.
That is how my buddy blew the head on my Civic. Car revved to 13k after redlining in 2nd going to 3rd and accidently went to 1st
Old Jul 9, 2013 | 04:11 PM
superlim9's Avatar
superlim9
I find absolutely little use for first gear anyways unless I'm in a parking garage, take it into downtown Seattle (cuz the hills suck), or trying to embarrass some HS kid in his parents AUDI... but deff. no need to downshift into 1st.
Old Jul 9, 2013 | 06:06 PM
HK350 Z's Avatar
HK350 Z
Old Jul 9, 2013 | 06:59 PM
stuartc323's Avatar
stuartc323
Civic of Dreams.
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
