no burn out
Old Jan 25, 2004 | 05:35 PM
philsill350z's Avatar
philsill350z
Default no burn out
why us it when i go to do a burn out and heat my tires up when i bounce off the clutch and on to the break the car seems to die down why is this anyone else have this?
Old Jan 25, 2004 | 06:01 PM
zand02max's Avatar
zand02max
Huh!
Old Jan 25, 2004 | 06:15 PM
mjedens's Avatar
mjedens
Default Power loss
Pull your break light fuse!!
Old Jan 25, 2004 | 06:16 PM
FLY BY Z's Avatar
FLY BY Z
Probably because you either:
1) Left the VDC/TCS on
2) Are not revving it high enough before dropping the clutch to break the tires loose.
Turn the VDC/TCS off and rev to 4K or more and drop the clutch. You may have problems with wheel hop though. Don't do this on the street unless you are under 18.
Old Jan 25, 2004 | 06:19 PM
jesseenglish's Avatar
jesseenglish
Brake lights kill the throttle. Pull the brake light fuse.
However if you're at the drag strip with stock tires, you're wasting your time trying to do a burnout. Plus we have independent rear suspension.
Wheel hop + IRS = Bad
Old Jan 26, 2004 | 10:02 AM
philsill350z
i have a base model so i have to pull my break light fuse and that will work wut fuse is it thanx guys
Old Jan 26, 2004 | 10:15 AM
PhoenixINX's Avatar
PhoenixINX
So you're going to burn out, warming up one tire.. and leaving the other cold???
Ehhhhh
Old Jan 26, 2004 | 10:36 AM
philsill350z
hmmmm no i plan on getting a rear done it was just a question on how to do it geeez
Old Jan 26, 2004 | 11:11 AM
ares's Avatar
ares
Veteran
your original post makes no sense. but generally you want to know how to do a burn out... as you know, you need to hold the brake or youll just take off. when the brake is pushed, the brake lights are on. when the lights are on it limits the engine throttle to 30%. by pulling the fuse, lights dont go on, throttle isnt limited.
none the less, you are not driving on drag radials, nor do you have an LSD, till you have both of those, burnouts are nothing but a waste of money and unnescessary stress on the car. unless your under 18.
Old Jan 26, 2004 | 11:18 AM
philsill350z
my plan s to get drag radials for the track and a lsd it was a simple question thats all no need to go into well you dont have an lsd dugh i know this i just asked how to get my wheels spinning
Old Jan 26, 2004 | 12:31 PM
ares's Avatar
ares
Veteran
throttle, sidestep clutch, hit the brake with the clutch foot. heel toe can help.
linelock is best if you plan to do this repeatedly. otherwise your braking to hold your front wheels in place. which will hold you still, but your back brakes are still spinning; kills your brakes and rotors. linelock holds the fluid pressure in the front.
Old Jan 26, 2004 | 12:56 PM
JFritz's Avatar
JFritz
This is a joke...........so don't take me seriously....especially if you're not from the U.S.
but some words of wisdom for you,
Before you mod your car, invest in yourself and take a spelling/grammar class or computer typing class. I can barely understand your posts.
apex locator
Jul 23, 2021 02:27 AM
allmycarsdie
May 13, 2016 04:38 PM
smithmt3
Sep 11, 2015 08:25 PM
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
themyst
Jan 6, 2003 01:27 PM
