Installing ACT lightweight Flywheel tonight!
Old Aug 7, 2013 | 03:25 PM
David_2613's Avatar
David_2613
Default Installing ACT lightweight Flywheel tonight!
I'm excited
Buddy (my work supervisor) has a lift in his rental unit and he is helping me swap my clutch. It's his birthday today, what a guy!
While we are in there we will be replacing the flywheel and pressure plate with ACT parts. I'll take pictures and post them up tomorrow.
Fingers crossed, no surprises!
Old Aug 8, 2013 | 05:03 AM
wird06's Avatar
wird06
Its not a bad install. I did one last weekend on a garage floor with no lift.
Old Aug 8, 2013 | 07:36 AM
David_2613's Avatar
David_2613
Getting the car into the garage
Definitely needed a new clutch
That OEM flywheel is loaded with metal, I was surprised how heavy it was.
Installed with used HDSS pressure plate
Old Aug 8, 2013 | 07:58 AM
wird06's Avatar
wird06
Yea went on a weight **** fest. ACT flywheel 16.9lbs (hd resurfaced)and stock flywheel was 28lbs.
Old Aug 8, 2013 | 11:33 AM
RENFRO's Avatar
RENFRO
Should make the revs a little quicker. I went with the Z1 flywheel. 13.7 lbs and I love it.
Old Aug 8, 2013 | 11:40 AM
David_2613's Avatar
David_2613
I'm also hoping it causes RPM's to drop just a quickly. If not, then the idle air control valve must play a significant roll. Probably not an issue once you install an EMS.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
