Help: Fast clutch break-in procedure!?
Old Aug 8, 2013 | 09:57 AM
David_2613's Avatar
David_2613
Default Help: Fast clutch break-in procedure!?
I replaced my clutch last night (Wed). ACT HDSS setup with resurfaced 17lb flywheel.
I am going to my first AutoX event on Saturday.
Any suggestions on bedding this new clutch in by Saturday?
I travel for my job and I may not get another chance to AutoX my car for another 6 months. At the same time, I REALLY do not want to have to change this disc again just because I was in a hurry.
Old Aug 8, 2013 | 10:47 AM
NissanZguy's Avatar
NissanZguy
500 mile break in period? Go on a long night time road trip.
Old Aug 8, 2013 | 11:11 AM
David_2613's Avatar
David_2613
Question is, how many start, stops, up and downshifts does the average car go through in 500 miles?
I'm thinking that a couple days of city traffic from hell in and around Dallas on city streets might be enough. Might be able to rack up the same amount of clutch usage in 50-100 miles.
What are your guys' thoughts?
Old Aug 8, 2013 | 11:23 AM
NissanZguy's Avatar
NissanZguy
Allot of variables to consider. However trying to take a short cut on a proper clutch break in procedure is probably not a good idea. GL
Old Aug 8, 2013 | 11:31 AM
RENFRO's Avatar
RENFRO
There will be more auto-x events. Break it in properly
Old Aug 8, 2013 | 01:25 PM
terrasmak's Avatar
Drive as normal, hit the auto cross and just drive. Main thing you do not want to do is a drag style start. Just short shift into 2nd and you are set. Most courses are 2nd gear only, once you are in gear you clutch is no longer needed.
Cliff notes
Easy out of gate
Short shift second
Don't worry after that.
Mine, I drive like an idiot from the day I installed it, have 115k miles on it now.
Old Aug 8, 2013 | 01:39 PM
David_2613's Avatar
David_2613
Thanks Terrasmak for the input, I will do just that.
As a first time AutoX-er, one of my main goals is to drive smoothly. This will fit perfectly within my game plan.
Cliff notes
Easy out of gate
Short shift second
Old Aug 8, 2013 | 05:21 PM
350z006's Avatar
350z006
Glad to hear the clutch works...glad it went to a good owner
BTW if you ever need upgrade, I'm currently running the ACT 6-puck/Xtreme pressure plate, and it's not bad at all, easier than my buddy's OS Giken Twin to drive
Old Aug 9, 2013 | 02:25 AM
dcains's Avatar
dcains
I must confess I've been driving MT cars since I began driving in '74, and never knew there was a break-in procedure for a new clutch. And, in all those years I've rarely had to replace a clutch, even though I'd consider myself a somewhat aggressive driver. Just lucky?
Old Aug 9, 2013 | 04:44 AM
wird06's Avatar
wird06
I like HPF clutch break in:
http://www.supraforums.com/forum/sho...-6-puck-clutch
Old Aug 9, 2013 | 05:08 AM
2bad240's Avatar
2bad240
Think about this race cars don't drive on the street they can't drive 500 miles. It's straight to the track.
In my personal vehicles its install then I burn out to make sure they hold and that's it.
Old Aug 9, 2013 | 06:53 AM
DaveJackson's Avatar
DaveJackson
Master
^Bot.
Old Aug 9, 2013 | 10:49 AM
NissanZguy's Avatar
NissanZguy
True Racing Clutches on race cars are also replaced more often than a street driven car. Some times after every session.
We're talking about a street/track clutch. So the break in procedure is going to be pretty different from a race only dedicated clutch/car.
Old Aug 11, 2013 | 10:59 AM
samsniss350z's Avatar
samsniss350z
Totally agree.
Old Aug 11, 2013 | 01:47 PM
David_2613's Avatar
David_2613
Thanks again terrasmak for putting my mind at ease. The AutoX event went great! In the novice group I placed 4th out of 12 with only 2 other drivers being complete newbs like me. And like you said, it was strictly a 2nd gear track.
I used the 2 days before the event focusing on breaking in the clutch. I am surprised how much the clutch has changed in feel over those 2 days. At first it was extremely grabby with a really stiff pedal. By the time saturday came, the clutch felt predictable and smooth. Engagement is about 1/3 of the way from the floor and the pedal doesn't feel as stiff.
Cheers!
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
