Blew headgasket, what else should I upgrade?
Old Aug 19, 2013 | 10:10 AM
mcarther101's Avatar
mcarther101
Default Blew headgasket, what else should I upgrade?
So I blew a head-gasket 99% sure. While I don't want to blow money for no reason, I was thinking about upgrading a few parts while the engine is apart.
-ARP Head Studs & Bolts... are these different than L19, why half the price?(https://www.extremepsi.com/store/pro...roductid=21002)
-HR Head Gasket
-what else should I upgrade that's easy/inexpensive to do so while it's apart?
Trying to keep the price reasonable, not trying to upgrade rods/pistons, etc... unless I found them for super cheap somewhere.
Old Aug 19, 2013 | 10:52 AM
terrasmak's Avatar
Na or FI? If NA, just run a set of HR head bolts.
Old Aug 19, 2013 | 12:21 PM
mcarther101
Hm, this seems to be the idea I see now. Found a guy selling HR head gasket & head bolts, but waiting on reply. I want these like - tomorrow lol.
Edit: Couldn't wait for a reply, Z1 Motorsport only had 1 set left, so I snagged them. Anyone know the specs on how much I have to shave the cylinder heads down to use the HR headbolts on the DE, or what exactly?
http://www.z1motorsports.com/350_g35...oducts_id=5010
http://www.z1motorsports.com/350_g35...oducts_id=4033
Old Aug 19, 2013 | 01:35 PM
tcode's Avatar
tcode
You don't want to shave cylinder heads more than it needed for resurfacing/cleaning. Otherwise, you will raise CR ratio too much. AFAIK HR bolts are longer but they should fit DE block. You need to grind coolant passages for using HR head gasket I believe.
Old Aug 19, 2013 | 04:11 PM
mcarther101
Thanks, had a more experienced mechanic come by today, and he doesn't think it's the head gasket. Now that I really look at the white smoke, and after already noticing there is no coolant smell, overheating issue, or otherwise... I am inclined to agree with him hoping it's just a sensor. As engine RPM increases, white smoke increases correspondingly (unburnt fuel)... and car falls through idle 90% of the time into a stall now. I'm going to replace the camshaft pos sensors in the hopes I don't have to shell out a G to fix this.
Old Aug 19, 2013 | 04:26 PM
1sickveilsidez's Avatar
1sickveilsidez
I would suggest changing both cam sensors and the crank. From experience when you change one the others will fail. Working at the dealer I saw this a lot and even with warning the customer about it they would come back a few days later to buy the others. Better to do it right the first time then to spend more time on it then necessary.
Old Aug 19, 2013 | 05:51 PM
mcarther101
Hm, didn't know this. Crank sensor is from the factory still at 116k miles I think. I will have to get it to a lift to try that out, I know there was a recall about that, and I don't think I ever had mine replaced. Going to toss one of those on tomorrow, still blowing white smoke for now with new cam sensors, but need to do an ECU reset (really doubt ECU reset is going to fix it at this point though lol).
Edit:
I noticed more oil than usual in the plenum when I removed it to get to the camshaft position sensors. A lot more than 900 miles worth of driving's oil, and it seemed dirtier than the usual slightly off brown oil residue you find in there.
Old Aug 19, 2013 | 07:11 PM
mcarther101
Reading on other people's posts with similar experiences I am wondering if I have a faulty fuel injector perhaps leaking obscene amounts of fuel into a cyllinder?
I decided to go for a short drive, and go WOT, then I would really blow whatever remnants of a headgasket I had left if that was the problem I thought I noticed at around 3/4 of the way to 6600RPM, I got a momentary jolt in acceleration, then back to super limp powerless mode. Maybe that "moment" where it accelerated was the "moment" it required just as much fuel as a broken fuel injector was constantly spraying regardless of RPM?
350z with similar problem:
Originally Posted by thirty5ounces
ok here ya go
FIRST THINGS FIRST,,,,,are you absolutely 100% positive there is no oil smoke??? Thats what i thought also, but unless its a huge cloud youwont tell....i smoked at anything over 2500K rpm when accelerating somewhat fast, it was a small cloud...but if i wot it would shoot out a larger cloud then stop, it would also smoke if i did city driving then say i pull in somewhere and rev teh motor a few times it would smoke the worse....didint really notice much smoking during down shifting....
now the fix,,,,i took it to a Z specialist (Z tech longwood florida) this was after i took it to nissan and they did a comp check and ecu check,,,,they found nothing wrong with the car,,,perfect compression and nothing on the comp,,,nissan couldnt explain why my car would smoke accelerating and while city driving for no reason.....at Z tech the owner ran my car for a day....home and back and to lunch,,,he wasnt sure where to start and he also did the comp check and comp check,,,everything was fine....he decided to flush the engine....3 TIMES
Now he did this because in the Left side of this motor runs alot hotter then the right,,,oil sludge is very common here....he took the valve cover off and cleaned all the ports....now i bought my car used, and when i purschaced my car the first thing i did was switch to AMSOIL OIL and TRANNY fluid....this can be bad if the person before you ran regular oil and was kind of lazy on the oil changes.....as you know amsoil breaks up sludge so it caused it to break up all sludge build up and put it everywhere.....causing the motor to work harder in higher rpms or when motor was warmed up.....
now after these flush's we took the car for a test run, "white" smoke still appearing....now we are really confused...comp wont pick up a damn thing and his engine flush didint work,,,no oil leaks,,,
next something with the fuel....we decided to clean all injectors....after he cleaned the fuel system, the smoke had decreased by 75%.....i ran it for a while and it would smoke but not near as bad....I stopped into advance and bought Fuel system cleaner that they had there.....i think it was an STP injector and fuel system cleaner...it stopped completely for a while....then started smoking a little two weeks later......
finally Jim at JWT.....Avee at Z tech knows jim personally so we decide to call Jim and see what he thought about this mystery......he thought we should do what we already done....engine flush,fuel system clean.....and other then that he HAD KNOW IDEA WWHAT TO DO....he was clueless and didnt have any ideas on what do to on this car,,,,never herd of this or seen these symptoms on a non-turbo car
here we are today my car has randomly stopped smoking for a month now dnt know why or how neither does Avee at Z tech , or Jim at JWT.......so thats y i say " good luck"
now you know why i didnt type the first time
From this thread... https://my350z.com/forum/maintenance...ease-help.html
Similar problem on other cars:
http://forums.nicoclub.com/running-r...p-t537337.html
http://forums.nicoclub.com/rough-idl...e-t518039.html
Old Aug 19, 2013 | 07:29 PM
1sickveilsidez
Usually when your cam sensors or crank sensor are bad the car will do what you just explained "momentarily jolt in acceleration."
I would suggest going to an autozone, o'reilly or whatever stores are around you like that and have them use there scanner and see what codes your car is throwing. Cheaper then going to the dealer. Then just reference those codes with google and you should find out what needs to be replaced.
Based on what you said I'm almost certain it's the senors.
Old Aug 19, 2013 | 08:00 PM
mcarther101
How many sensors do we have in total? If it's not the crank pos sensor, I'm running out of ideas lol. Guy dropped by my house today and doesn't think it's o2 sensors because they don't come into play until the car warms up apparently. I took apart intake valve solenoids, and they look super clean. Just replaced camshaft position sensors, no effect. MAF sensor looks to be reading normally (although I broke the clip today damnit). So if it isn't crank pos sensor then it's either a faulty fuel injector, or blown head gasket. I'm going to pick up a set of used fuel injectors on here to swap for testing purposes, and might as well upgrade for $60. Both are easy things to check before I get serious and commit to tearing off the cylinder heads
Old Aug 19, 2013 | 08:11 PM
1sickveilsidez
Car has 3, 2 cam sensors and 1 sensor for the crank. As I mentioned just have autozone/o'reilly use the scan tool and see what codes pop up before going in and throwing parts at it you don't need. Easiest way to diagnose the problem.
Old Aug 20, 2013 | 09:24 AM
mcarther101
Ah, yeah I know that. I mean besides 3x o2 sensors, 2x intake valve solenoids, MAF, 2x camshaft pos sensors, & crank pos sensor... what else is there to check? I'm about to go to autozone, we'll see if the codes changed at all.
Also, bought some OEM 335cc injectors off a forum member for $60, might as well right. I'll probably replace crank pos sensor to rule it out, and pull spark plugs to see which cylinder is having problems, if any one in particular.
Old Aug 22, 2013 | 09:01 PM
mcarther101
Update, initial diagnosis was accurate: blew my head gasket or cracked a cylinder head. Likely not the latter but the former, we'll see.... but I guess I am one of those 1% of drivers that is too much for the stock '03 VQ35DE's tolerances ...or at least I prefer to think that
Other thread detailing the final diagnosis of the blown head gasket:
https://my350z.com/forum/maintenance...-hates-me.html
Rebuild thread started:
https://my350z.com/forum/na-builds/5...cams-port.html
