jwt flywheel install
Old Oct 17, 2013 | 07:15 PM
max-hid's Avatar
max-hid
Default jwt flywheel install
Im havin problem installing the jwt flywheel becuase its hard to enter the flywheel to the cranckshaft... its normal that the center its little smaller than the original one??
Old Oct 17, 2013 | 09:00 PM
samsniss350z's Avatar
samsniss350z
How much smaller are you talking? Are you saying that its an interference fit or worse?
Old Oct 18, 2013 | 03:43 AM
max-hid's Avatar
max-hid
To put it i had to put the flywheel and the with the bolts i have to tight them in sequence that the flywheel enter in the center but its tight.. sorry for my english
Old Oct 18, 2013 | 05:18 PM
SlowCoupe's Avatar
SlowCoupe
Not normal. Did you line up the pin on the crack and the back of the flywheel?
Old Oct 18, 2013 | 07:07 PM
jerryd87's Avatar
jerryd87
sounds like you didnt line it up and smashed the locating dowel, which means the car wont start since its out of alignment. as the saying goes with cars, if you have to force it, stop and look
