JWT flywheel problem
Old Oct 29, 2013 | 02:02 PM
Toxikoman's Avatar
Toxikoman
Default JWT flywheel problem
I had install a new flywheel and clutch from JWT in the car-service, but after the first 200 miles I noticed a problem. In the car-service discovered That screws of pressure plate in flywheel have failed (did not hold properly). The screws go out along with cases (springs). Has anyone had a similar problem? Any advice what to do?
Old Oct 29, 2013 | 03:12 PM
mcarther101's Avatar
mcarther101
The replaceable friction plate on the flywheel came unscrewed? Sounds like they weren't torqued down enough perhaps? Did you check the torque specs prior to installation, not sure what they're supposed to be honestly myself off-hand. Is this what you mean?
Old Nov 20, 2013 | 03:13 AM
tony_theturtle's Avatar
tony_theturtle
sdkjfd
Old Nov 20, 2013 | 03:14 AM
tony_theturtle
ere
Uriyo_
Sep 8, 2021 08:46 AM
