OEM flywheel bolts $4.88 x 8. Fastenal $0.3403.
$40 + shipping for OEM bolts that sometimes break when they are reused is ridiculous. The flywheel bolt size is M10x1.0 with a 25mm length. Socket cap bolts from Fastenal are class 12.9 which can probably be reused multiple times and are less than $1.00. Just need to be weight balanced.
Fastenal socket head cap bolts
Fastenal cap bolt
OEM http://www.courtesyparts.com/12310a-...4_715_716_724&
Fastenal cap bolt
I hate those damn torx bolts for the flywheel... A hex head like everyone else uses would be so much nicer... Why would you need to balance it for the bolts, they are all the same distance from the center hole and should weight the same
I'm picky, but yes, they should be good to go.
Fastenal cap bolt
Fastenal cap bolt
I Didnt have a Flywheel bolt to compare. There is a Fastenal 10 mins from me. lol
